This is going to be embarrassingly obvious, but a lack of sleep and looking too closely has blinded me to the obvious:
int v=0; // The value being constructed from individual characters
Serial.println("Input an integer value:");
while(Serial.available()==0) {} // Wait for input
while(Serial.available()>0) { // While there are characters to process...
v*=10; // Shift v
v+=Serial.read()-48; // Add next character to v (-48 converts from ASCII to decimal)
Serial.println(v,DEC); //COMMENT OUT TO GET THE PROBLEM
Serial.print("Constructed integer value: ");
If you remove the Serial.println statement as indicated, see what happens to the output. -only the first digit is processed. The question is, why?
The ATmega's processor is orders of magnitude faster than serial I/O. Your code incorrectly assumes that the whole string has been transmitted once the first character shows up.
By sticking the serial.print() in there, you effectively delay the input processing enough to allow all the characters to arrive.
A better (baud rate independent, requiring minimal time) method would be to simply wait until serial.available() returns 5 if you are always expecting exactly 5 digits. Another method is to built up the integer until you read a newline character (or some other terminator).
Thanks for that. What began as a quick and nasty method of dropping into a service mode and changing some tuning variables on the fly looks like becoming a bit of a library!
