Fried input pin?
Hi all,
Whilst interfacing with an LM1815 IC I seem to have killed the the digital input.
All was working well - but now it seems to go a bit mental. Tried a simple button input and that plays up as well.
Can I just replace the main Arduino chip?
James
It's worth a shot.
How do the other digital inputs behave? Can you just switch over to a different one?
I want to use the 2 and 3 pins as I am using interrupts :slight_smile:
I've ordered a new chip so will wait and see :slight_smile:
You can also use the pin change interrupts on any I/O pin instead of the dedicated interrupt pins on PD2 and PD3.
Say that again?
I can use other pins with attachInterrupt? How so?
Sorry, you have to "color outside the lines" a bit. attachInterrupt() does not support the pin-change feature of the microcontroller yet.
The pin-change interrupts are documented in Section 10 of the ATmega328 datasheet.
You could, for example, use digital pin 8 (Port B pin 0):
  PCMSK0 = _BV(PCINT0); // Enable PCINT group 0
  PCICR = _BV(PCIE0); // Enable PCINT0, (Port B pin 0)
ISR(SIG_PIN_CHANGE0) {
  // handle pin change interrupt
Digital pins are in sets of ports? Maybe I have only fried one port... I can try that code and see if it's just the port A or pin 3 and 4...
Thanks!
If you need to know which pin actually caused the interrupt, you'll have to take care of that yourself with pin change interrupts!
Any pin in a pin group will fire the interrupt if it changes.
