Hi everyone,
I have GPS module which has only communication protocols are USB and UART. I found a GPS library as Sparkfun u-blox GNSS Arduino Library. Library
The case is that library was developed to I2C communication.
Read NMEA sentences over I2C using Ublox module SAM-M8Q, NEO-M8P, ZED-F9P, etc
By: Nathan Seidle
SparkFun Electronics
Date: August 22nd, 2018
License: MIT. See license file for more information but you can
basically do whatever you want with this code.
This example reads the NMEA setences from the Ublox module over I2c and outputs
them to the serial port
Feel like supporting open source hardware?
Buy a board from SparkFun!
ZED-F9P RTK2: https://www.sparkfun.com/products/15136
NEO-M8P RTK: https://www.sparkfun.com/products/15005
SAM-M8Q: https://www.sparkfun.com/products/15106
Hardware Connections:
Plug a Qwiic cable into the GPS and a BlackBoard
If you don't have a platform with a Qwiic connection use the SparkFun Qwiic Breadboard Jumper (https://www.sparkfun.com/products/14425)
Open the serial monitor at 115200 baud to see the output
#include <Wire.h> //Needed for I2C to GPS
#include "SparkFun_Ublox_Arduino_Library.h" //http://librarymanager/All#SparkFun_u-blox_GNSS
SFE_UBLOX_GPS myGPS;
Serial.println("SparkFun Ublox Example");
Wire.begin();
if (myGPS.begin() == false)
Serial.println(F("Ublox GPS not detected at default I2C address. Please check wiring. Freezing."));
while (1);
//This will pipe all NMEA sentences to the serial port so we can see them
myGPS.setNMEAOutputPort(Serial);
myGPS.checkUblox(); //See if new data is available. Process bytes as they come in.
delay(250); //Don't pound too hard on the I2C bus
How can I use this sketch for USB communication or Serial communication. I'm not familiar with this so I need your help.
Thank You.
