Maybe a stupid question but its one that i need to ask. I am a newbee in electronics and i have made a simple prototype with the arduino, all is working well and the programm is behaving like it was programmed too.
Now i would like to go beyond the arduino and make it into a single piece of hardware.
The following questions pop in mind:
Can i use the same atmel as on the arduino?
do i need to burn a bootloader on it or can i burn my programm on a empty atmel?
Could i use the Arduino to burn my programm on an empty atmel or do i need another programmer for the task?
I hope i have made my questions clear and sorry if they are a bit dumb but like i said i am a newbee wrestling through the wonders of electronics
Another question, you have mentioned to buy a seperate programmer. I know for PC users there is alot to choose from, the problem is that i am working on OSX which has only usb and firewire connections. What programmer is usb and would work with my mac (brand, make etc)
Also a website of that particular atmel programmer would be nice, kind of curious on what kind of atmel chips i can use with it.
Also would it be possible to burn directly to the programmer using the arduino sketch software, i noticed there is a new version (00011) which mentions something like that in the improvemend release notes.
Thank you so much for the answers!
I don't have one myself but this one:
seems to be the one most commonly used... (its USB)
@triffid That link is what i need! Thanks
Looks like an affordable usb programmer, i do read that the firmware needs to be installed through linux before the programmer will be OS independend thats a bit of a bummer since i do not have a working linux machine anymore, but i do know people that have so i will ask around!
and parallel......i know that its simple but like i said before i am working on a G5 which doesn't have parallel or serial ports for that mather anymore, thats why it needs to be usb as i don't wanna work on converting stuff using parallel to usb converters.
Anyway are there people here that work with this programmer on OSX? What are the experiences?
The "AVR ISP mkII" mentioned in the link http://www.atmel.com/dyn/products/tools_card.asp?tool_id=3808 sells for 40Euros in Germany. You'll miss the fun of soldering the SMD-parts, but if its only for the money you should check you local resellers.
Herzliche dank fur der Tip Eberhard!!!, i got friends in germany so if for some reason buying in the netherlands is more expensive i will ask one of my friends to order and ship it to me! But i will call my local electronics reseller first.....
