Hello
I am new to this forum so sorry if I make some kind of mistake.
I have some code for reading the temperature from 4 analog inputs with 4 different temperature probes. On UNO everything works perfectly. As I need more PINs I want to move to MEGA but the readings on MEGA are completely wrong. The mega keeps returning only the values from 1 and 2 (and wrong) and nothing for 3 and 4. Also when nothing is connected to the analog pins it keeps returning some values that of course are wrong.
I tried so far a capacitor, adding 9V battery to power supply, adding an external reference (5v) but it did not work till now.
I would be glad if somebody could help me with the problem. I am posting now only the code for two analog readings but it is the same for 3 and 4 as for the code shown below.
byte NTCPin1 = A0;
#define SERIESRESISTOR1 100000
#define NOMINAL_RESISTANCE1 100000
#define NOMINAL_TEMPERATURE1 25
#define BCOEFFICIENT1 3950
const int numReadings1 = 60;
int readings1[numReadings1]; // števila iz analogengega vhoda
int readIndex1 = 0; // postavimo začetni indeks na 0
float total1; // skupni seštevek
float average1;
byte NTCPin2 = A1;
#define SERIESRESISTOR2 100000
#define NOMINAL_RESISTANCE2 100000
#define NOMINAL_TEMPERATURE2 25
#define BCOEFFICIENT2 3950
const int numReadings2 = 60;
int readings2[numReadings2]; // števila iz analogengega vhoda
int readIndex2 = 0; // postavimo začetni indeks na 0
float total2; // skupni seštevek
float average2;
for (int thisReading1 = 0; thisReading1 < numReadings1; thisReading1++) {
readings1[thisReading1] = 0;
for (int thisReading2 = 0; thisReading2 < numReadings2; thisReading2++) {
readings2[thisReading2] = 0;
void loop(){
float ADCvalue1;
float Resistance1;
float ADCvalue2;
float Resistance2;
ADCvalue1 = analogRead(NTCPin1);
ADCvalue2 = analogRead(NTCPin2);
//Serial.print("Analog value ");
//Serial.print(ADCvalue1);
//Serial.print(" = ");
Resistance1 = (1023 / ADCvalue1) - 1; //vrednost spremenimo v upornost
Resistance1 = SERIESRESISTOR1 / Resistance1;
Resistance2 = (1023 / ADCvalue2) - 1; //vrednost spremenimo v upornost
Resistance2 = SERIESRESISTOR2 / Resistance2;
//Serial.print(Resistance1);
//Serial.println(" Ohm");
float steinhart1;
steinhart1 = Resistance1 / NOMINAL_RESISTANCE1; // (R/Ro)
steinhart1 = log(steinhart1); // ln(R/Ro)
steinhart1 /= BCOEFFICIENT1; // 1/B * ln(R/Ro)
steinhart1 += 1.0 / (NOMINAL_TEMPERATURE1 + 273.15); // + (1/To)
steinhart1 = 1.0 / steinhart1; // Invertiramo
steinhart1 -= 273.15; // konverzijav stopinje
Serial.print("Temperature 1 ");
total1 = total1 - readings1[readIndex1]; // Kalkulacija po steinhartovi enačbi
readings1[readIndex1] = steinhart1; // preberi senzor
total1 = total1 + readings1[readIndex1]; // dodaj kar prebere v skupni seštevek
readIndex1 = readIndex1 + 1; // pomakni števnik za eno gor
if (readIndex1 >= numReadings1) { // če smoprišli do konca štetja postavi števec na 0
readIndex1 = 0;
average1 = (total1 / numReadings1)*0.983; //deli skupno število z številom odčitkov da dobiš povprečje. to množimo še z korekcijskim faktorjem
if (average1 >= 102) { // vsi ndaljni if stavki namenjeni korekturi odčitkov iz senzorja
average1 = average1 * 0.985;
else if ((average1 >= 100)&&(average1 < 102)){
average1 = average1 * 0.970;
else if ((average1 >= 90)&&(average1 < 100)){
average1 = average1 * 0.972;
else if ((average1 >= 80)&&(average1 < 90)){
average1 = average1 * 0.974;
else if ((average1 >= 74)&&(average1 < 80)){
average1 = average1 * 0.979;
else if ((average1 >= 65)&&(average1 < 74)){
average1 = average1 * 0.987;
else if ((average1 >= 55)&&(average1 < 65)){
average1 = average1 * 0.992;
else {
average1;
if (average1 >= 5) { // če je manj kot 5 stopinj ne prikaži. to je zato ker če sonda ni priključena kaže čudna števila
Serial.println(average1);
else {
Serial.println(0);
delay(1); // zakasnitev zaradi stabilnosti
///////////////////////////SENZOR 2/////////////////////////////
float steinhart2;
steinhart2 = Resistance2 / NOMINAL_RESISTANCE2; // (R/Ro)
steinhart2 = log(steinhart2); // ln(R/Ro)
steinhart2 /= BCOEFFICIENT2; // 1/B * ln(R/Ro)
steinhart2 += 1.0 / (NOMINAL_TEMPERATURE2 + 273.15); // + (1/To)
steinhart2 = 1.0 / steinhart2; // Invertiramo
steinhart2 -= 273.15; // konverzija v stopinje
//Serial.print("Temperature 2 ");
total2 = total2 - readings2[readIndex2]; // Kalkulacija po steinhartovi enačbi
readings2[readIndex2] = steinhart2; // preberi senzor
total2 = total2 + readings2[readIndex2]; // dodaj kar prebere v skupni seštevek
readIndex2 = readIndex2 + 1; // pomakni števnik za eno gor
if (readIndex2 >= numReadings2) { // če smoprišli do konca štetja postavi števec na 0
readIndex2 = 0;
average2 = (total2 / numReadings2)*0.983; //deli skupno število z številom odčitkov da dobiš povprečje. to množimo še z korekcijskim faktorjem
if (average2 >= 100) { // vsi ndaljni if stavki namenjeni korekturi odčitkov iz senzorja
average2 = average2 * 0.968;
else if ((average2 >= 90)&&(average2 < 100)){
average2 = average2 * 0.972;
else if ((average2 >= 80)&&(average2 < 90)){
average2 = average2 * 0.974;
else if ((average2 >= 74)&&(average2 < 80)){
average2 = average2 * 0.979;
else if ((average2 >= 65)&&(average2 < 74)){
average2 = average2 * 0.987;
else if ((average2 >= 55)&&(average2 < 65)){
average2 = average2 * 0.992;
else {
average2;
if (average2 >= 5) {
//Serial.println(average2);
else {
//Serial.println(0);
delay(1); // zakasnitev zaradi stqbilnosti odčitkov
