From Uno to to mega
Hello,
I am trying to connect a Leddar M16 to my arduino Mega, it worked fine on my UNO using the code bellow.
I am using a linksprite RS485Shiled v2.1
Simple Leddar(TM) Example - Without LCD
Language: Arduino
This program lists the detections read on the serial port of the Arduino.
Can be used with Arduino IDE's Serial Monitor.
Shields used:
  • RS-485 Shield
Created 01 Jun. 2015
by Pier-Olivier Hamel
This example code is in the public domain.
#include <Leddar.h>
Leddar16 Leddar1(115200,1);
//Baudrate = 115200
//Modbus slave ID = 01
//Initialize Leddar
Leddar1.init();
char result = Leddar1.getDetections();
if (result >= 0)
for (int i = 0; i < Leddar1.NbDet; i++)
Serial.print("Segment: ");
Serial.print(Leddar1.Detections*.Segment);*
  • Serial.print(" Distance: ");*
    _ Serial.print(Leddar1.Detections*.Distance);_
    _
    Serial.print("\n");_
    _
    } _
    _
    }_
    _
    else*_
    * Serial.print("Error: ");*
    * Serial.print((int)result);*
    * Serial.print("\n");*
    * delay(50);*
    Do I need to change anything to the code? I keep getting error -2
    Thx for the help!
Did you made it italic? Please use code tags, see How to use the forum.
And if you include non-standard libraries, give a link to them. We simply don't know every library in the world....
Beardedmaker:
I bet that's not the whole error.... :wink: Please post the whole error :slight_smile:
Which is a ? Using duct tape? Super glue? Rubber bands?
