It appears you have a messed up reset circuit. You have a cap from pin 1 to pin 3? That cap should go between pin 1 and whatever pin is the DTR signal on the FTDI module. That allows the arduino IDE software to generate a auto-reset function required before a upload can take place. Otherwise you need to remove the cap and properly wire in a reset switch, which you then have to press and release at just the correct time. Auto-reset is the way to go as I'm sure that your FTDI module provides the DTR signal.
retrolefty:
oh right. Im an idiot. I changed the board but I still get the same error message... Does that mean my FT232R is blown? I am choosing Arduino Duemilanove or Nano w/ ATmega328 under Tools/Board. Attached is a new pic with the cap moved. Have I anything else messed up?
fabienLyrique:
Yes, still messed up. You need to wire the cap to the DTR D....T....R signal on the FTDI module. It will be one of the side contacts on that module, you will have to look at a drawing to figure out which pin it is on.
It worked!!! I am such a NoooooooooooB. I thought you were using some other acronym for the transmission pin.. but low and behold, I turn the thing upside down and there sitting in front of my nose is DTR! Thanks so much.
