FSM Library (playground)- how to use "current state"?
Hello,
i'd like to use the FSM Library.
http://playground.arduino.cc/Code/FiniteStateMachine
Everything is fine, but i don't understand this function:
State& getCurrentState()
"Returns the current state"
May someone give me an example so i can understand how to check the current state of a FSM?
Don't know how to write it down. :~
Greetz Chris
The definition of the function is:
This means that the function returns a reference to a previously defined object. So it hands you back a reference to one of the State objects you created. It's pretty much the same as a pointer, but it's safer because you have to initialize a reference, so you don't have to check for NULL pointers. For example:
State goingOnce = State(firstChance);
State goingTwice = State(secondChance);
State gone = State(tooLate);
FSM auctionMachine = FSM(goingOnce);
  if (digitalRead(BID_PIN) == HIGH) {
    State& currentState = auctionMachine.getCurrentState();
    // currentState is now a reference to one of the three State objects I declared above
    // either goingOnce, goingTwice or gone
    if (currentState === gone) {        // I used exactly equal but you don't have to
      Serial.println("Too late!");
void firstChance(void) {
void secondChance(void) {
void tooLate(void) {
Thank you so much! Now it’s clear! :slight_smile:
Do you know other examples refering to this library?
I only found the example at the playground.
Greetz Chris
Glad it helped. No, sorry, I haven't seen examples of anyone else using it.
This doesn’t compile
Of course not. There is no setup() function, and no #include statements. http://snippets-r-us.com is down the road a ways.
