FSR controlled timing for an LED
I’m trying to write a program to time how long a Force Sensing Resistor is pressed then turns on a LED for the same amount of time. I have tested the circuit and found the FSR returns a value of 200 when lightly pressed. In my program I attempted to assign the input from the FSR under 200 to be a LOW value and over 200 as a HIGH value. It doesn’t work so hot. I would appreciate any help in trouble shooting my code.
const int buttonPin = A0;
int buttonState = 0;     // current state of the button
int lastButtonState = 0; // previous state of the button
int startPressed = 0;    // the moment the button was pressed
int endPressed = 0;      // the moment the button was released
int holdTime = 0;        // how long the button was hold
int idleTime = 0;        // how long the button was idle
int timeActive = 0;       // how long the function will run
  pinMode(buttonPin, INPUT); // initialize the button pin as a input
  pinMode(13, OUTPUT);        // initialize pin 13 as output
  buttonState = analogRead(buttonPin); // read the button input
  if (buttonState < 199) {
    buttonState == LOW;
  if (buttonState > 200) {
    buttonState == HIGH;
  if (buttonState != lastButtonState) { // button state changed
     updateState();
  lastButtonState = buttonState;        // save state for next loop
void updateState() {
  // the button has been just pressed
  if (buttonState == HIGH) {
      startPressed = millis();
      idleTime = startPressed - endPressed;
  // the button has been just released
   else {
      endPressed = millis();
      holdTime = endPressed - startPressed;
  timeActive = (holdTime);
     digitalWrite (13, HIGH);
      delay (holdTime);
     digitalWrite (13, LOW);
      delay (1000);
So, if buttonState == 200 or buttonState == 199, do nothing at all?
    buttonState == LOW;
You also treat buttonState alternatively as a logic or a numerical value:
I see that you convert the numerical value to a logic value, but this is terribly unconventional and confusing. You should capture the analog value with a separate, appropriately named variable like ‘buttonValue’.
    //buttonState == LOW;
    buttonState = LOW;
    //buttonState == HIGH;
    buttonState = HIGH;
You should be using = (assignment) in this block not == (comparison).
Awesome. Thank you for your time and help. I added a buttonValue int to capture the data and changed the comparisons to <= and >=. The program works great and I really appreciate your help.
I noticed I was having some problems with artifacts and I needed to debounce my switch. So I followed the debouncing tutorial but now the light doesn’t come on at all. Any ideas as to why? Do I need to add an int for the Millis?
int buttonState = HIGH;     // current state of the button
int buttonValue = 0;     // capture the analog data from the sensor
int lastButtonState=LOW; // previous state of the button
int timeCalc = 0;       // Calculation from hold time
int timeActive = 0;     // how long the function will activate
int reading = HIGH;
unsigned long lastDebounceTime = 0;  // the last time the output pin was toggled
unsigned long debounceDelay = 200;    // the debounce time; increase if the output flickers
   buttonValue = analogRead(buttonPin); // read the button input
  if (buttonValue <= 199) {
    reading = LOW;
  if (buttonValue >= 200) {         // resitance over 200 will act like having pushed a button
    reading = HIGH;
      // If the switch changed, due to noise or pressing:
  if (reading != lastButtonState) {
    // reset the debouncing timer
    lastDebounceTime = millis();
  if ((millis() - lastDebounceTime) > debounceDelay) { //debounce delay
    if (reading !=buttonState) {
      buttonState = reading;
     updateState();
  lastButtonState = reading;        // save state for next loop
   else {
      holdTime = ((endPressed - startPressed)/1000.00);
 timeCalc = (holdTime);
    timeActive =  (timeCalc);
      delay (timeActive);
You don’t have a digital switch you have an FSR and I think that having an appropriate hysteresis band on the analog readings is going to be a more effective approach than using debounce techniques. Does this eliminate the “artifacts”?
const int fsrPin = A0;
int fsrValue;
int fsrState = 0;     // current state of the fsr
int lastfsrState = 0; // previous state of the fsr
int startPressed = 0;    // the moment the fsr was pressed
int endPressed = 0;      // the moment the fsr was released
int holdTime = 0;        // how long the fsr was hold
int idleTime = 0;        // how long the fsr was idle
  pinMode(fsrPin, INPUT); // initialize the fsr pin as a input
  fsrValue = analogRead(fsrPin); // read the fsr input
  if (fsrValue < 100) {
    fsrState = LOW;
  if (fsrValue > 300) {
    fsrState = HIGH;
  if (fsrState != lastfsrState) { // fsr state changed
    Serial.print("StateChange ");
    if (fsrState == LOW)
      Serial.println("LOW");
      Serial.println("HIGH");
    updateState();
  lastfsrState = fsrState;        // save state for next loop
  // the fsr has been just pressed
  if (fsrState == HIGH) {
  // the fsr has been just released
  else {
    delay (holdTime);
    delay (1000);
