FSR LED System
I also posted this in the sensor forum, let me know if crossposting is not allowed
Hi all,
I am building a small project that has 3 LEDs and an FSR sensor. Essentially, I want each LED to light up SEPARATELY as more pressure is applied. Here is what I want in pseudo code.
0-50 - no LEDs are lit
50-400 - only first LED is lit
400 - 700 - only second LED is lit
700 - 1000 - only third LED is lit
my serial print is working, and the FSR is projecting a nice range from 0-900
my code at the moment just lights up the first two, and the pressure controls brightness for some reason, even though I never defined brightness as a value.
HERE IS MY CODE
int sensorPin = A0;
int ledPin1 = 13;
int ledPin2 = 11;
int ledPin3 = 10;
int sensorValue = 0;
int noPressure = 50;
int lowPressure = 400;
int goodPressure = 700;
int hiPressure = 1000;
 pinMode(sensorPin, INPUT);
 pinMode(ledPin1, OUTPUT);
 pinMode(ledPin2, OUTPUT);
 pinMode(ledPin3, OUTPUT);
 sensorValue = analogRead(sensorPin); //reads pin value, assigns it to sensorValue
 Serial.println(sensorValue);
 if (sensorValue <= noPressure)
   digitalWrite(ledPin1, LOW);
   digitalWrite(ledPin2, LOW);
   digitalWrite(ledPin3, LOW);
 if (sensorValue < lowPressure)
   digitalWrite(ledPin3, HIGH);
 else(ledPin3, LOW);
 if (sensorValue < goodPressure)
   digitalWrite(ledPin2, HIGH);
 else(ledPin2, LOW);
 if (sensorValue < hiPressure)
 else(ledPin3, LOW);
Hello @georgiaes,
georgiaes:
It is not. Other thread removed.
Assume sensorValue is 23. Start at the first if statement...
Work your way down through the code. Try to determine how execution flows (which then-clauses run because the if-condition is true). I find a print out and pen to be useful for such things.
Can you see why the program is doing what it is doing?
Delta_G:
Please read the "How to use this forum" thread at the top of any of the message boards. In the coding and electronics world, a good starting place is always to read the instructions.
That would also help you a lot with your current dilemma. If you'll look at some code examples, you'll notice that NONE of them look like
else(ledPin3, LOW);
Uh oh. How do you have things wired up? Do you have resistors on those LEDs?
Hi, thanks for the response. I will review other coding examples, I am pretty new to programming. Do you have any suggestions on how I can apply (properly notated) if/else statements to my project?
I am confident in my wiring, I have resistors on each LED and I have run my current set-up through a simpler project to see if each of the LEDs were working properly.
