FSR - need output in weight [kg/lbs]
For one of my wearable project I am using the sensor Flexiforce A301 [https://www.tekscan.com/products-solutions/force-sensors/a301] to sense weight.
I am a Textile Graduate, with no knowledge in coding.
I dont know how to get the output in weight [kgs/lbs]
I dont know the formula I should use here to convert the force[Newton] reading to weight[kg/lb].
For reference, I have used this code attached.
To obtain the formula, you have to calibrate the sensor using known standards. Adafruit has a pretty good tutorial. Why Calibrate? | Calibrating Sensors | Adafruit Learning System
If you already have the force in Newtons, just divide that by 10 (or 9.8 if you must) to get kg. Then multiply the kg by 2.2 to get pounds.
