FSR sensor ( counter ) problem
This the code for FSR sensor counter..
int fsrPin = 0; // the FSR and 10K pulldown are connected to a0
int fsrReading; // the analog reading from the FSR resistor divider
int counter = 0;
void setup(void) {
// We'll send debugging information via the Serial monitor
fsrReading = analogRead(fsrPin);
Serial.print(counter);
Serial.println(" steps");
if (fsrReading > 10 && fsrReading < 350)
counter=counter + 1;
delay(100);
The problem with this coding is fsrReading > 10 && fsrReading < 350 , the sensor will keep counting...
What i want is, if the FSR detect range 10 - 350 , the counter just count 1 only... From my code above, the sensor will keep counting when the sensor in the range..
I try to do in this way .. Let say if the FSR detect in range 10 - 350, the count will start count 1 and stay 1 if still in the range.. Then when it below 10, the counter will not count and then, it count 1 again when reach within the range. (just only one not will continously counting if still in the range)
hope u all understand what i try to explain..
Please help me in advance..
  static byte isReading;
  if (fsrReading > 10 && fsrReading < 350 && !isReading)
    isReading = 1;
  else if (isReading)
    isReading = 0;
  delay(100);
Refer to the code you give..
I had try and the result still continuous counting when in range threshold..
is it possible arduino count just only 1 if it in threshold...(not continuous count).
because i want to make FSR as a step counter.
but the problem is when it in range threshold, the counter will continuously counting.
When a person step on a FSR, it will count and doesnt matter how long time it step on the FSR.the FSR will count 1 and if he/she make another step, it will count as 2..
Sorry I don't have an Arduino free to test the code with and I'm not seeing my bug.
I was a bit surprised by this at first, but I get excellent results by treating an FSR exactly like a tact switch. The code below illustrates this, using a debounce library that I wrote. I have the FSR connected to A0, but it is used as a digital input; any digital or analog pin can be used. I use the AVR's internal pullup so no external resistors are required.
//Counter using a Force-Sensitive Resistor (FSR) as input.
//Connect the FSR from the designated pin to ground, with no
//pullup or pull-down resistors.
//Works with this FSR https://www.sparkfun.com/products/9376
#include <Button.h>              //http://github.com/JChristensen/Button
#define FSR_PIN A0               //connect fsr from this pin to ground
#define PULLUP true              //use the AVR's internal pullup resistor
#define INVERT true              //low level means fsr pressed
#define DEBOUNCE_TIME 50         //milliseconds
Button fsr = Button(FSR_PIN, PULLUP, INVERT, DEBOUNCE_TIME);
int counter;
void setup(void)
void loop(void)
    fsr.read();
    if (fsr.wasPressed()) {
        Serial.print(++counter, DEC);
Do you want your counter to increment one time for each time the (FSR) reading goes from outside your range to inside it? In that case, you need a variable (one that keeps its value between calls to loop) to hold the previous state, namely inside vs. outside the signal band of interest. So, I think you may want something like:
#define LOW_THRESH (10)
#define HIGH_THRESH (350)
#define FSR_PIN (whatever)
static boolean prevInRange = false; // persistent variable for previous state
int fsrVal;
int count = 0;
boolean curInRange;
fsrVal = analogRead(FSR_PIN);
if ((fsrVal >= LOW_THRESH) && (fsr_val <= HIGH_THRESH)) { // is FSR inside defined band?
curInRange = true;
if ( (prevInRange == false) && (curInRange == true)) { // then we've just transitioned into the band
count +=1; // increment once per outside-to-inside transition
prevInRange = curInRange; // update history for next time
// Your serial output code goes here
Hope this helps.
