Hello,
I want to use an Interlink FSR sensor but even Interlink advices not to solder the sensor.
How would you achieve a both solid and affordable connexion with this sensor without soldering ?
Thank you in advance.
Hello,
I was thinking about a part allowing to solder the cable on one end first and crimp the sensor on the other end afterwards.
Could one of the linked products be of any use ?
http://www.piecesbuggy.com/cosse-double-femelle-isolee-sachet-p-632.html
That should work fine, I bought what was desrcibed at phone connectors basically 22 gauge butt connectors, and used on various transistors, sensors, etc when im too lazy to solder or where soldering is too complex
Thanks winner10920 !
