FSR to MIDI response and latency?
So I'm working on an FSR-based midi controller, something like an M-Audio Trigger Finger. My problem is with the latency and response of the FSR. For extended presses, the velocity responds fine, but for quick touches it is only registering a velocty of 0-4, if that. It will only register different velocities after a continued hold of 100 or 200 ms.
Is this a weakness of FSR sensors, and why many still use piezo sensors? Or is there something sloppy about this code that is slowing it down?
Code:
//credit to thedude77
#include <MIDI.h>
MIDI_CREATE_DEFAULT_INSTANCE();
int fsrC = 0;                  //FSR is on pin 0
int fsrVal = 0;                //variable for reading FSR value
int mappedFsrVal = 0;          //variable for holding remapped FSR value
int prevFsrVal = 0;               //variable for storing our prev FSR value
void loop(){
   fsrVal = analogRead(fsrC);         //read input from FSR
   mappedFsrVal = map(fsrVal, 0, 1000, 0, 127);  //map value to 0-127
   if(analogRead(fsrC)){//still too slow for instantaneous hits
    // midiOUT(0xB0, 6, mappedFsrVal); //CC Volume message
     midiOUT(0x90, 60, mappedFsrVal); //MIDI noteOn
     midiOUT(0x80, 60, mappedFsrVal);//MIDI noteOff   channel,note,velocity
    delay(100);//
void midiOUT(char command, char value1, char value2) {
  Serial.write(command);
  Serial.write(value1);
  Serial.write(value2);
My other issues is with rapid fire messages during a sensor hold, but I'll probably figure that out in time. Thanks all! XD
Hi pjamesvilla
Not sure why you are reading the analog pin again? Since the value read will always / often be greater than 0, the if statement will always / often execute anyway.
    delay(100);//
There is a 100ms delay after sending the MIDI messages and before doing another analogRead(). So, this sets a minimum time before changing the pressure on the FSR will be noticed.
Regards
Ray
Thanks Hackscribble!
I'm trying to have the FSR trigger only one note when it is continuously pressed. Haven't seen a copy/paste solution yet, so I came up with a sort of placeholder value that changes any continued pressed to velocity CC's with a nested if. Probably not the most elegant approach. Getting a logic error though:
//credit to thedude77, roguescience
#include <MIDI.h>
int holder = 0;
void loop(){
   mappedFsrVal = map(fsrVal, 100, 1000, 5, 127);  //map value to 0-127
   if(analogRead(fsrC))  && holder = 0
     prevFsrVal = mappedFsrVal;
     holder = holder +1
     if(holder = 1 && analogRead(FsrC)      {//break out of loop to stop rapid fire?
     midiOUT(0xB0, 60, mappedFsrVal);
    delay(100);//
