Fstream does not work
Hi Guys,
I am new to this set-up and started to have problems while compiling the program. This is the snapshot of my code:
#include <fstream>
  std::fstream file;
  file.open("abc.txt", std::ios::out | std::fstream::app);
  if(!file.is_open()) {
    Serial.println("ERROR1: FILE NOT OPENED.");
There is nothing inside loop function. it is empty.
Problem is that for some reason, I see this message:
I would like to understand why. There are no issues during the compilation as well. I would be happy to write more if needed.
does "abc.txt" exist?
does is need to be "created"?
Are you using an ESP32? If so, this will help: Std::fstream with ESP32 - #4 by maxgerhardt - espressif32 - PlatformIO Community
It does not exists. It needs to be created new. I think the probable reason could be of non-availability of the file system on my(esp) processor.
Thanks for the pointer man. Cheers!
"open" typically fails if the file doesn't exist. there's probably a CREATE option, for when a file is written to for the first time
I tend to use append instead of open for file creation. With append if the file does not exist then create it and then open it for append.
Hi gcjr,
Thanks for the reply.
Open does not mean that it is opening in read mode. It can also open in write mode as well, depending on the options you pass.
Thanks Idahowalker. I think the reason is the non-availability of the file system at the esp processor system.
and those options include create/append for when a file may not exist
