So I have Arduino Pro Mini 3.3V 8Mhz and FT2232H Mini Module.
Loopback test passes, wether it's COM39 on Windows 10 or /dev/ttyUSB0 on Linux(debian stable).
I have tried all possible combinations of rotating anything but VCC. Sometimes lights on arduino start flashing all the time, sometimes only when I run Upload sketch or avrdude on linux manually.
Uploading sketch on Windows:
Sketch uses 928 bytes (3%) of program storage space. Maximum is 30720 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x6b
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x6b
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x6b
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x6b
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x6b
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x6b
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x6b
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x6b
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x6b
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x6b
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
Error on Linux (for google indexing):
avrdude -c 2232HIO -p m328
E avrftdi_program_enable(880): Device is not responding to program enable. Check connection.
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.avrdude done. Thank you.
avrdude on linux is version 6.3-20160220
avrdude-dev mail list says nothing yet, maybe they are mad how uneducated I am maybe something else.
Mini module schematics
FT2232H schematics
What I am doing wrong ?
Thank you in advance
