I am the sort of engineer that likes to do things from scratch to get a good understanding of how things work. I've been
writing and testing some FT800 functions to try and get a good understanding of how the chip works. It's hard going as the information supplied by FTDI is not detailed enough.
Any way, I have a problem with bitmaps. I can display all the widgets and also display a small bitmap loaded into RAM_G however if I try and display a widget with text in I.e Buttons, keys, text the bitmap appears as a solid colour block . With no text teh bitmap is fine.
Any help would be great.
Thanks
Paul
Thanks but I'm trying to work out what I'm doing wrong without using someone else's library. Do you know it it is possible to display a bitmap and a button with text in the same display list?
Sorted!!
Turned out to be some sort of interference from the serial print function. Commenting out Serial.begin fixed it.
