hello
excuse for my bad English i recently started to run 7" lcd with FT810 driver with arduino mega board and show some bitmaps and icons, so i tried to use gameduino library to run the lcd, problem is the library tries to calibrate touch panel at the beginning and i want to desible the touch configuration cause i don't want to use touch in this project, can anyone help me runing the code without using a touch ?
I'm using gd3.h library
thanks
I haven't tried using the GD2/GD3 library yet, but from a quick look at the gd2-lib library on GitHub I think you might be able to do either of the following:
- In GD2.h, change the
#define CALIBRATION from 1 to 0
- In your sketch: I'm not sure what parameters you are currently passing in to the
GD.begin() call, but you could try adding in ~GD_CALIBRATE:
- eg.
GD.begin(~GD_CALIBRATE) or GD.begin(GD_TRIM | GD_STORAGE)
Inside of the GDx.h file of the gameduino library:
Set
#define GD_CALIBRATE 0 // enable touchscreen calibration at startup
In order to avoid the touch calibration in the startup of the TFT.
