ftdi basic board and cp2102 converter question
Hello, i have an arduino mini and recently bought the ftdi basic breakout board to program the mini as it has no usb.
Is it possible to use the cp2102 usb/ttl converter to do the same job as the ftdi board ?
Thank you
Yes. Make sure to get one that either brings DTR out to a header pin (a fairly recent change in boards being offered), or at least brings it to a hole where you can add your own header pin (or lets you easily add a jumper from the hole to a header pin, cutting the trace that connects the header to the CP2102 reset input pin).
Hello, thank you for your reply.
I have found that topic about it
