TX and RX-led are on (and stay on) when plugging into USB
Arduino board is now recognized as a 'USB to Serial' device instead of 'FT232RL USB UART '
I do have the same problem on my other pc (where I didn't change anything to the software/Arduino environmen etc.). So it must be the board. I'm guessing it is the FTDI (I did a EE_READ and EE_WRITE :()
I hope someone or a board developer can help me out of this mess :'(, I'm missing my lovely board ;)
I tried the same and my board (with FT232BL) is still working. I see an option in USBTransfer that says EEWriteDef (set to default). I don't know if it works, but you can try. The Arduino board uses the FTDI chip with the default settings.
I did an EEWriteDEf, and also installed the newest drivers.
Now the Arduino is recognized as "USB Serial Converter" and "USB Serial Port (COM14)".
The TX and RX led on the board are now "off" when there is no data send or transmit. When I try to upload a sketch to the board, the TX led flickers one time (very short) en the Arduino IDE (0007 Alpha) is returning: "Programmer is not responding". Tried the 0009 Alpha also -> "avrdude: ser_open(): can't open device "COM14": Het systeem kan het opgegeven bestand niet vinden."
A few days before this problem, I was able to upload sketches...
I do hope someone can help me (and my Arduino board :))
Now Arduino is @ COM Port 6 (‘USB Serial Converter’ → USB HUB as well as ‘USB Serial Port (COM6)’) are visible in Control Panel > System > …
I reprogrammed the FTDI-chip with the default settings from the datasheet.
What still looks strange is when I press the ‘RESET’-button, the LED @13 don’t flash for a short time when the bootloader is loaded… (I also replaced the ATMEGA168 with a new one which came with a preprogrammed bootloader on it). The POWER led is indicating that the Arduino board is powered bij USB (of course ;))
Maybe can someone with the information above do some ‘in brain debugging’? lol
Feeeeeeeeew, I’m almoast out of options I’m afraid…
Hmm, if you reset the board, does the LED on pin 13 flash once? If not, it sounds like you got a chip that doesn’t actually have the bootloader on it. If it does flash, it may be that the FTDI chip is still incorrectly configured.
No -> I replaced the new ATMEGA168 with the old one -> LED on pin 13 flash once ;D
Then I reprogrammerd the default settings into the FTDI-chip...
And it is working!!! ;D ;D ;D
Thanks a lot mellis and the others :-)
I can play again with my Arduino ;D Wihaaaaa
I would like to post the default settings in MProg-format, is there somewhere space available at arduino.cc of the playground? If someone has the same problem(s) it could be handy :-)
