There is no display on the screen. This is the error message I get when I try to run the code.
In file included from sketch/FT_VM800P43_50.h:64:0,
from /Users/rishabhbhardwaj/Documents/Arduino/_5inchLCD/_5inchLCD.ino:30:
sketch/hardware/FT800/FT800.h:542:0: warning: "DISPLAY" redefined [enabled by default]
#define DISPLAY() ((0UL<<24))
In file included from sketch/_5inchLCD.ino.cpp:1:0:
/Users/rishabhbhardwaj/Downloads/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino/Arduino.h:55:0: note: this is the location of the previous definition
#define DISPLAY 0x1
In file included from sketch/FT_VM800P43_50.h:67:0,
sketch/libraries/FT_GC/FT_Transport_SPI/FT_Transport_SPI.h:215:37: error: 'prog_uchar' has not been declared
void Writefromflash(uint32_t Addr, prog_uchar *Src, uint32_t NBytes)
In file included from sketch/FT_VM800P43_50.h:68:0,
sketch/libraries/FT_GC/FT_GC.h:325:32: error: 'prog_uchar' has not been declared
FT_GEStatus WriteCmdfromflash(prog_uchar *Src,uint32_t NBytes);
sketch/libraries/FT_GC/FT_GC.h:329:35: error: 'prog_uchar' has not been declared
FT_GEStatus TransferCmdfromflash(prog_uchar *Src,uint32_t NBytes);
sketch/libraries/FT_GC/FT_GC.h:1656:52: error: 'FT_GEStatus FT_GC<FT_Trans>::TransferCmdfromflash' is not a static member of 'class FT_GC<FT_Trans>'
FT_GEStatus FT_GC<FT_Trans>::TransferCmdfromflash( prog_uchar *Src,uint32_t NBytes)
sketch/libraries/FT_GC/FT_GC.h:1656:52: error: template definition of non-template 'FT_GEStatus FT_GC<FT_Trans>::TransferCmdfromflash'
sketch/libraries/FT_GC/FT_GC.h:1656:52: error: 'prog_uchar' was not declared in this scope
sketch/libraries/FT_GC/FT_GC.h:1656:64: error: 'Src' was not declared in this scope
sketch/libraries/FT_GC/FT_GC.h:1656:77: error: expected primary-expression before 'NBytes'
sketch/libraries/FT_GC/FT_GC.h:1766:49: error: 'FT_GEStatus FT_GC<FT_Trans>::WriteCmdfromflash' is not a static member of 'class FT_GC<FT_Trans>'
FT_GEStatus FT_GC<FT_Trans>::WriteCmdfromflash( prog_uchar *Src,uint32_t NBytes)
sketch/libraries/FT_GC/FT_GC.h:1766:49: error: template definition of non-template 'FT_GEStatus FT_GC<FT_Trans>::WriteCmdfromflash'
sketch/libraries/FT_GC/FT_GC.h:1766:49: error: 'prog_uchar' was not declared in this scope
sketch/libraries/FT_GC/FT_GC.h:1766:61: error: 'Src' was not declared in this scope
sketch/libraries/FT_GC/FT_GC.h:1766:74: error: expected primary-expression before 'NBytes'
exit status 1
Error compiling for board Arduino/Genuino Uno.
The code I have for the LCD screen
* Copyright (c) Future Technology Devices International 2014
* propriety of Future Technology devices International.
* Software License Agreement
* This code is provided as an example only and is not guaranteed by FTDI.
* FTDI accept no responsibility for any issues resulting from its use.
* The developer of the final application incorporating any parts of this
* sample project is responsible for ensuring its safe and correct operation
* and for any consequences resulting from its use.
* @file HelloWorld.ino
* @brief Sketch to display hello world on FT800.
Tested platform version: Arduino 1.0.4 and later
* @version 0.1.0
* @date 2014/17/05
/* This application demonstrates the usage of FT800 library on VM800P4350 platform */
/* Arduino standard includes */
#include "SPI.h"
#include "Wire.h"
/* Platform specific includes */
#include "FT_VM800P43_50.h"
/* Global object for FT800 Implementation */
FT800IMPL_SPI FTImpl(FT_CS_PIN,FT_PDN_PIN,FT_INT_PIN);
/* Api to bootup ft800, verify FT800 hardware and configure display/audio pins */
/* Returns 0 in case of success and 1 in case of failure */
int16_t BootupConfigure()
uint32_t chipid = 0;
FTImpl.Init(FT_DISPLAY_RESOLUTION);//configure the display to the WQVGA
delay(20);//for safer side
chipid = FTImpl.Read32(FT_ROM_CHIPID);
/* Identify the chip */
if(FT800_CHIPID != chipid)
Serial.print("Error in chip id read ");
Serial.println(chipid,HEX);
return 1;
/* Set the Display & audio pins */
FTImpl.SetDisplayEnablePin(FT_DISPENABLE_PIN);
FTImpl.SetAudioEnablePin(FT_AUDIOENABLE_PIN);
FTImpl.DisplayOn();
FTImpl.AudioOn();
return 0;
/* API to display Hello World string on the screen */
void HelloWorld()
/* Change the below string for experimentation */
const char Display_string[12] = "Hello World";
/* Display list to display "Hello World" at the centre of display area */
FTImpl.DLStart();//start the display list. Note DLStart and DLEnd are helper apis, Cmd_DLStart() and Display() can also be utilized.
FTImpl.ColorRGB(0xFF,0xFF,0xFF);//set the color of the string to while color
FTImpl.Cmd_Text(FT_DISPLAYWIDTH/2, FT_DISPLAYHEIGHT/2, 29, FT_OPT_CENTER, Display_string);//display "Hello World at the center of the screen using inbuilt font handle 29 "
FTImpl.DLEnd();//end the display list
FTImpl.Finish();//render the display list and wait for the completion of the DL
/* bootup the module and display "Hello World" on screen */
/* Initialize serial print related functionality */
/* Set the Display Enable pin*/
Serial.println("--Start Application--");
if(BootupConfigure())
//error case - do not do any thing
HelloWorld();
Serial.println("--End Application--");
/* Nothing in loop api */
Please help. I have been stuck for weeks now. :((
