My arduino mega 1280 works propely, that means, it executes the sketch it currently has in its memory.
Problem is, if i plug it to the computer it says "device not recognized", so I assume the bulit-in ftdi converter is dead. How can i still program the atmega using a "common" ftdi adapter??
Ludo91:
By wiring the send and receive TTL serial signal lines from the new ftdi to pins 0 and 1 (or is that 1 and 0, I always get in mixed up ) on the arduino mega shield connector, plus a ground wire from the FTDI adapter to a arduino ground pin, and you should be back in business.
But first you should check to make sure you don't just have a corrupted or missing FTDI USB driver in your PC. Try deleting it and re-installing the FTDI driver and see if that works before going with a new external FTDI serial cable.
Lefty
Also you can buy another ftdi and replace it without too much troubles, just normal soldering iron.
With a steady hand and good eyesight...
I would not do it that way (with a hot air gun) myself, if you are really 100% sure the chip is dead, carefully cut the legs from the body and then desolder whats left.
It did worked wiring to the serial 0 tx n
rx, many thanks to all of you.
