I have a circuit with an ATmega328p hooked up to a 16Mhz oscillator. When I properly connect an FTDI device, it always gives me the same error.
enabled in File > Preferences.
Arduino: 1.0.5 (Mac OS X), Board: "ATmega328P-PU (16MHz Crystal)"
Binary sketch size: 1,082 bytes (of a 30,720 byte maximum)
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avrdude -C/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega328p -cstk500v1 -P/dev/tty.AdafruitEZ-Link35b2-SPP -Uflash:w:/var/folders/z4/22r0ynkn0gl0nsq8r01bnwrm0000gn/T/build9159934491349898627.tmp/Blink.cpp.hex:i
avrdude: Version 5.11, compiled on Sep 2 2011 at 18:52:52
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/etc/avrdude.conf"
User configuration file is "/Users/James/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/tty.AdafruitEZ-Link35b2-SPP
Using Programmer : stk500v1
avrdude: Send: 0 [30] [20]
avrdude: ser_recv(): programmer is not responding
avrdude done. Thank you.
I have tried with 3 different FTDI devices, (not the CH340G)
I have Vcc hooked to Vcc,
Rx goes to Tx,
Tx goes to Rx,
GND to GND,
DSR or CTS to GND,
DTR to a 0.1uF electrolytic capacitor in series (+ to RESET, - to DSR) to RESET
The ATmega328p has properly hooked up 16Mhz crystal with 2 22pF capacitors as recommended, there is a 10kohm resistor from Vcc to RESET as recommended...yet the same error.
I am wondering what I am doing wrong because all of these FTDI devices work when attached to an UNO or a MICRO, but never standalone.
Try the Loopback test as a start.
CTS (clear to send, from the slave device) should connect to GND, lets the host know it can send data.
The driver may ignore it. Or it may require it. I’ve always connected it.
Nothing echoes back...but occasionally I get this error
java.io.IOException: Device not configured in writeArray
at gnu.io.RXTXPort.writeArray(Native Method)
at gnu.io.RXTXPort$SerialOutputStream.write(RXTXPort.java:1124)
at processing.app.Serial.write(Serial.java:526)
at processing.app.Serial.write(Serial.java:549)
at processing.app.SerialMonitor.send(SerialMonitor.java:203)
at processing.app.SerialMonitor.access$100(SerialMonitor.java:35)
at processing.app.SerialMonitor$3.actionPerformed(SerialMonitor.java:92)
at javax.swing.JTextField.fireActionPerformed(JTextField.java:492)
at javax.swing.JTextField.postActionEvent(JTextField.java:705)
at javax.swing.JTextField$NotifyAction.actionPerformed(JTextField.java:820)
at javax.swing.SwingUtilities.notifyAction(SwingUtilities.java:1645)
at javax.swing.JComponent.processKeyBinding(JComponent.java:2859)
at javax.swing.JComponent.processKeyBindings(JComponent.java:2894)
at javax.swing.JComponent.processKeyEvent(JComponent.java:2822)
at java.awt.Component.processEvent(Component.java:6191)
at java.awt.Container.processEvent(Container.java:2084)
at java.awt.Component.dispatchEventImpl(Component.java:4776)
at java.awt.Container.dispatchEventImpl(Container.java:2142)
at java.awt.Component.dispatchEvent(Component.java:4604)
at java.awt.KeyboardFocusManager.redispatchEvent(KeyboardFocusManager.java:1856)
at java.awt.DefaultKeyboardFocusManager.dispatchKeyEvent(DefaultKeyboardFocusManager.java:722)
at java.awt.DefaultKeyboardFocusManager.preDispatchKeyEvent(DefaultKeyboardFocusManager.java:1000)
at java.awt.DefaultKeyboardFocusManager.typeAheadAssertions(DefaultKeyboardFocusManager.java:865)
at java.awt.DefaultKeyboardFocusManager.dispatchEvent(DefaultKeyboardFocusManager.java:686)
at java.awt.Component.dispatchEventImpl(Component.java:4648)
at java.awt.Window.dispatchEventImpl(Window.java:2492)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:717)
at java.awt.EventQueue.access$400(EventQueue.java:82)
at java.awt.EventQueue$2.run(EventQueue.java:676)
at java.awt.EventQueue$2.run(EventQueue.java:674)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.AccessControlContext$1.doIntersectionPrivilege(AccessControlContext.java:86)
at java.security.AccessControlContext$1.doIntersectionPrivilege(AccessControlContext.java:97)
at java.awt.EventQueue$3.run(EventQueue.java:690)
at java.awt.EventQueue$3.run(EventQueue.java:688)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:687)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:296)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:211)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:201)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:196)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:188)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:122)
Unfortunately no response, let me try the drivers...even though Im sure I have tried that before
Installed Drivers again, does not work...I simply cannot understand how my board could possibly be wrong...
Its not my computer, I have tried others, its not the FTDI, I have tried others, I have tried other ATmega328p's, I have tried breadboard, nothing works
The only thing I have not tried was using Windows OS, but I have never seen anything about OSX not working, and I have done a lot of research on this problem...
