FTP client con GSM Shield
Ciao a tutti,
ho appena acquistato un GSM shield(http://arduino.cc/en/Main/ArduinoGSMShield).
Il mio obbiettivo è riuscire a usare la GSM shield per connettermi ad un mio server FTP e uploadare dei file di log.
Usando Arduino Ethernet tutto bene(Arduino Playground - HomePage).
Invece con la GSM shield ho un grosso problema:
   FTP passive client for IDE v1.0.1 and w5100/w5200
   Posted October 2012 by SurferTim
#include <MemoryFree.h>
#include <SD.h>
#include <SPI.h>
#include <GSM.h>
// comment out next line to write to SD from FTP server
#define FTPWRITE
// PIN Number
#define PINNUMBER ""
// APN data
#define GPRS_APN       "mobile.vodafone.it" // replace your GPRS APN
#define GPRS_LOGIN     ""    // replace with your GPRS login
#define GPRS_PASSWORD  "" // replace with your GPRS password
// initialize the library instance
GPRS gprs;
GSM gsmAccess;
GSMClient client;
GSMClient dclient;
// URL, path & port (for example: arduino.cc)
//char server[] = "arduino.cc";
byte server[]= {xxxxxxxxx};
char path[] = "/";
int port = 21; // port 80 is the default for HTTP
char outBuf[30];
char outCount;
// change fileName to your file (8.3 format!)
char fileName[13] = "test.txt";
  if(SD.begin(4) == 0) //changed to 53 for use with mega
    Serial.println(F("SD init fail"));
Serial.println("Starting Arduino web client.");
  // connection state
  boolean notConnected = true;
   Serial.print("freeMemory()=");
    Serial.println(freeMemory());
  // After starting the modem with GSM.begin()
  // attach the shield to the GPRS network with the APN, login and password
  while(notConnected)
    if((gsmAccess.begin()==GSM_READY) &
        (gprs.attachGPRS(GPRS_APN, GPRS_LOGIN, GPRS_PASSWORD)==GPRS_READY))
      notConnected = false;
      Serial.println("Not connected");
  Serial.println("connecting...");
  delay(2000);
  Serial.println(F("Ready. Press f or r"));
  byte inChar;
  inChar = Serial.read();
  if(inChar == 'f')
    if(doFTP()) Serial.println(F("FTP OK"));
    else Serial.println(F("FTP FAIL"));
  if(inChar == 'r')
    readSD();
File fh;
byte doFTP()
  fh = SD.open(fileName,FILE_READ);
  /*if(!fh)
    Serial.println(F("SD open fail"));
    return 0;
  Serial.println(F("SD opened"));*/
  if (client.connect(server,21)) {
    Serial.println(F("Command connected"));
  else {
    fh.close();
    Serial.println(F("Command connection failed"));
    return 0;
  delay(3000);
  if(!eRcv()) return 0;
  client.println(F("USER xxx"));
  client.println(F("PASS xxx"));
  client.println(F("SYST"));
  client.println(F("PASV"));
  char *tStr = strtok(outBuf,"(,");
  Serial.print("La risposta e ");
  Serial.println(tStr);
  int array_pasv[6];
  for ( int i = 0; i < 5; i++) {
    tStr = strtok(NULL,"(,");
    array_pasv[i] = atoi(tStr);
    if(tStr == NULL)
      Serial.println(F("Bad PASV Answer"));
  unsigned int hiPort,loPort;
  Serial.println(array_pasv[3]);
  Serial.println(array_pasv[4]);
  hiPort = array_pasv[3] << 8;
  loPort = array_pasv[4] & 255;
  Serial.print(F("Data port: "));
  hiPort = hiPort | loPort;
  Serial.println(hiPort);
  if (dclient.connect(server,hiPort)) {
    Serial.println(F("Data connected"));
  else {
    Serial.println(F("Data connection failed"));
    client.stop();
    fh.close();
    return 0;
  client.print(F("STOR "));
  client.println(fileName);
  if(!eRcv())
    dclient.stop();
    return 0;
  Serial.println(F("Writing"));
  byte clientBuf[64];
  int clientCount = 0;
  while(fh.available())
    clientBuf[clientCount] = fh.read();
    clientCount++;
    if(clientCount > 63)
      dclient.write(clientBuf,64);
      clientCount = 0;
  if(clientCount > 0) dclient.write(clientBuf,clientCount);
  dclient.stop();
  Serial.println(F("Data disconnected"));
  client.println(F("QUIT"));
  client.stop();
  Serial.println(F("Command disconnected"));
  fh.close();
  Serial.println(F("SD closed"));
  return 1;
byte eRcv()
  byte respCode;
  byte thisByte;
  while(!client.available()){ delay(1); Serial.print("NON DISPONIBILE");};
  respCode = client.peek();
  boolean ciao=false;
  outCount = 0;
  while(client.available())
    thisByte = client.read();
    Serial.write(thisByte);
    if(((char)thisByte)=='(')
      ciao=true;
    if(ciao){
    if(outCount < 29)
      outBuf[outCount] = thisByte;
      outCount++;
      outBuf[outCount] = 0;
  if(respCode >= '4')
    efail();
    return 0;
  return 1;
void efail()
  byte thisByte = 0;
  while(!client.available()) delay(1);
  client.stop();
  fh.close();
void readSD()
  if(!fh)
    return;
    Serial.write(fh.read());
  fh.close();
Arduino stabilisce la prima connessione, invia username, password...
La connessione dati però non va a buon fine.
Mi chiedo se la libreria sia in grado di stabilire più connessioni simultanee e se ho sbagliato qualcosa in questa unione veloce di codice. Spero di avere più risposte di lui(GSM Shield and FTP - Networking, Protocols, and Devices - Arduino Forum)...
Quindi nessuno usa ftp?
