FTP Client
i have an Arduino Ethernet and a GSM Shield.
I would to upload a file through FTP.
There isn't a FTP function and i thought abouth using AT commands directly.
I'm able to connect with an own FTP server with authentication but i don't understand how i can upload a file that is in SD card.
#include <GSM.h>
#include <GSM3ShieldV1ModemVerification.h>
//#include <SD.h>
// set up variables using the SD utility library functions:
/*Sd2Card card;
SdVolume volume;
SdFile root;
File myFile;
const int chipSelect = 4;
  delay(2000);
  delay(2000);
  pinMode(10, OUTPUT);
  if (!SD.begin(4)) {
    Serial.println("initialization failed!");
    return;
  Serial.println("initialization done.");
  if (SD.exists("test.txt")) {
    Serial.println("example.txt exists.");
  else {
    Serial.println("example.txt doesn't exist.");
   GSM3ShieldV1DirectModemProvider modemAccess;
  int result=0;
  String modemResponse;
  // check modem response
  modemAccess.begin();
  // reset hardware
  modemAccess.restartModem();
  modemResponse=modemAccess.writeModemCommand("AT", 1000);
  if(modemResponse.indexOf("OK")>=0)
    Serial.println("OK");
  modemResponse=modemAccess.writeModemCommand("ATE0", 1000);
  Serial.println(modemResponse);
  modemResponse=modemAccess.writeModemCommand("AT+QIFGCNT=0", 1000);
  Serial.print("USER ");
  modemResponse=modemAccess.writeModemCommand("AT+QFTPUSER=\"xxxxx\"", 1000);
  modemResponse=modemAccess.writeModemCommand("AT+QFTPPASS=\"xxxxxx\"", 1000);
 long int start=millis();
  while(1)
    Serial.print((char)modemAccess.read());
    if(millis()-start>10000)
  Serial.print("FTP OPEN ");
  modemResponse=modemAccess.writeModemCommand("AT+QFTPOPEN=\"84.253.166.42\",21", 1000);
  delay(2000);
  start=millis();
  while(1)
  modemResponse=modemAccess.writeModemCommand("AT+QFTPPATH=\"/\"", 1000);
  delay(2000);
  start=millis();
  while(1)
Thank you for your attention.
Did you ever manage to solve this issue?
I solved it.
