FTP: how to write some string into text file?
Hello,
Working FTP client code, tested on ESP32
#include <WiFi.h>
#include <SD.h>
#include <SPI.h>
#define FTPWRITE
const char* ssid     = "SSID";
const char* password = "PASSWORD";
IPAddress local_IP(192, 168, 0, 240);
IPAddress gateway(192, 168, 0, 230);
IPAddress subnet(255, 255, 255, 0);
IPAddress primaryDNS(8, 8, 8, 8);
IPAddress secondaryDNS(8, 8, 4, 4);
// FTP Server
IPAddress server( 192, 168, 0, 250 );
WiFiClient client;
WiFiClient dclient;
char outBuf[128];
char outCount;
// change fileName to your file (8.3 format!)
char fileName[13] = "test.txt";
  // Configures static IP address
  if (!WiFi.config(local_IP, gateway, subnet, primaryDNS, secondaryDNS)) {
    Serial.println("STA Failed to configure");
  // Connect to Wi-Fi network with SSID and password
  Serial.print("Connecting to ");
  Serial.println(ssid);
  WiFi.begin(ssid, password);
  delay(10000);
  while (WiFi.waitForConnectResult() != WL_CONNECTED) {
    Serial.println("Connection Failed! Rebooting...");
    delay(5000);
    ESP.restart();
  Serial.println("Connected to wifi");
  printWifiStatus();
  Serial.print("FTP server:");
  Serial.println(server);
  doFTP();
File fh;
byte doFTP()
  if (client.connect(server, 21)) {
    Serial.println(F("Command connected"));
  else {
    fh.close();
    Serial.println(F("Command connection failed"));
    return 0;
  if (!eRcv()) return 0;
  client.println(F("USER ftp_username"));
  client.println(F("PASS ftp_password"));
  client.println(F("SYST"));
  client.println(F("PASV"));
  char *tStr = strtok(outBuf, "(,");
  int array_pasv[6];
  for ( int i = 0; i < 6; i++) {
    tStr = strtok(NULL, "(,");
    array_pasv[i] = atoi(tStr);
    if (tStr == NULL)
      Serial.println(F("Bad PASV Answer"));
  unsigned int hiPort, loPort;
  hiPort = array_pasv[4] << 8;
  loPort = array_pasv[5] & 255;
  delay(10000);
  Serial.print(F("Data port: "));
  hiPort = hiPort | loPort;
  Serial.println(hiPort);
  if (dclient.connect(server, hiPort)) {
    Serial.println(F("Data connected"));
  else {
    Serial.println(F("Data connection failed"));
    client.stop();
    fh.close();
    return 0;
#ifdef FTPWRITE
  client.println(F("CWD /TEST"));
  client.print(F("STOR "));
  client.println(fileName);
#endif
  if (!eRcv())
    dclient.stop();
    return 0;
  dclient.stop();
  Serial.println(F("Data disconnected"));
  client.println(F("QUIT"));
  client.stop();
  Serial.println(F("Command disconnected"));
  fh.close();
  Serial.println(F("FTP closed"));
  return 1;
byte eRcv()
  byte respCode;
  byte thisByte;
  while (!client.available()) delay(1);
  respCode = client.peek();
  outCount = 0;
  while (client.available())
    thisByte = client.read();
    Serial.write(thisByte);
    if (outCount < 127)
      outBuf[outCount] = thisByte;
      outCount++;
      outBuf[outCount] = 0;
  return 1;
void printWifiStatus() {
  Serial.println("");
  Serial.println("WiFi connected.");
  Serial.print("SSID: ");
  Serial.println(WiFi.SSID());
  IPAddress ip = WiFi.localIP();
  Serial.print("IP Address: ");
  Serial.println(ip);
  Serial.print("Gateway: ");
  Serial.println(WiFi.gatewayIP());
  Serial.print("Subnet: ");
  Serial.println(WiFi.subnetMask());
  Serial.print("Primary DNS: ");
  Serial.println(primaryDNS);
  long rssi = WiFi.RSSI();
  Serial.print("signal strength (RSSI):");
  Serial.print(rssi);
  Serial.println(" dBm");
It create empty test.txt to FTP server in these lines:
#ifdef FTPWRITE
#endif
Is it possible to fill test.txt with some string (eg. "test 12345") just before client.print(F("STOR "))?
How to do it?
I am not real programmer, just copy & paste programmer.
Hoping someone with better knowledge than me would reply, guide me please.
Thanks for the helpers! :slight_smile:
