Fuel Gauge IC for Primary Cell Charge Monitoring
I want to use a fuel gauge IC for charge monitoring a primary battery (either lithium manganese dioxide or lithium thionyl chloride) in my wireless sensor node project. The goal is to power the sensor using a primary battery for 10 years without replacement.
I would like to ask whether the following fuel gauge ICs, which are primarily designed for Li-ion cells, are suitable for monitoring primary battery charge:
  1. LTC2941 / LTC2942
  2. MAX17201 / MAX17205 / MAX17215
I am aware that TI’s BQ35100 and Analog Devices’ LTC3337 are specifically designed for primary batteries. However, I’m interested in exploring the LTC2941/LTC2942 due to their smaller size.
This is the image that i found on the digikey website. As it can seen a coin cell (primary) battery is connected to the LTC2942.
The way one of us would get the answer is by reading the datasheet. The way we find datasheets is with Google.
Interesting, the parts you mentioned work with I2C which generally requires a processor to read/write/program them. With a 10 year life requirement what processor are you planning on using?
MGM240 zigbee module (microcontroller with 2.4Ghz wireless communication capability)
What battery have you chosen? How will you control the current usage.
