Hey everyone, bit of a newby here but any help would be greatly appreciated.
I am trying to install a fuel level sensor in a tank depth of around ~100mm for an automotive/motorsports application. I have either decided to go for a more complicated capacitive solution or due to time restraints go for a simpler reed switch operation. The tank is filled with a foam type material to reduce sloshing during driving.
Basically due time/budget restrictions I think I will have to go with the Reed switch option. I have only been able to source 1 uk supplier of a capacitive fuel level sensor, which was quoted around £530. Does anyone know of any other suUK ppliers that will supply a quantity of 1?
I have a few questions about the reed switch operation in automotive/motorsport applications:
- If i am to place 4 switches in a line, 100%,75%,50% and 25%, how likely is it that this will be suitable due to sloshing of fuel? If anyone can point in the direction of an example/project for guidance, as I can only find two.
- Would say taking a running average over 5 seconds to display to the LEDS representing the level be appropriate to cut out enough error??
If anyone has any past experience or knowledge with a similar project that would be great help. Sorry for the help required not being explicitly arduino related but again any help would be greatly appreciated.
Hope you all had a good christmas.
