full-duplex between two arduino
Can I connect two arduino without ethernet in wireless?
And also need to be full-duplex? Thanks :slight_smile:
@ymj1225
Your topic was Moved to it's current location / section as it is more suitable.
Could you also take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
Full Duplex Wireless, as in transmitting and receiving at the same time ?
Not at all easy, the transmitting module will interfere with the receiving one.
Perhaps explain what the project actually is and exactly why you want full duplex ?
Yes, very easy if you use the built in UART, Softwareserial will not work it is a simplex implementation. To save a lot of greef get Arduinos with two serial ports (UARTs) built in such as the MEGA.
