Full ESP32 control for Ender 3
Hello, I have created this server to control Ender 3 using ESP32 Cam. I have an actual image from the printer(I can also do a timelapse), I can upload *.gcode files to a shared SD card and then print from it, and serial communication also works, except for one small problem. For commands like G28 for autohome there is no problem because the serial output from the printer is short, but in cases like M503 the output is long, something like that:
>>> M503
SENDING:M503
echo:; Linear Units:
echo:  G21 ; (mm)
echo:; Temperature Units:
echo:  M149 C ; Units in Celsius
echo:; Filament settings (Disabled):
echo:  M200 S0 D1.75
echo:; Steps per unit:
echo:  M92 X79.00 Y79.60 Z400.00 E102.80
echo:; Max feedrates (units/s):
echo:  M203 X500.00 Y500.00 Z10.00 E60.00
echo:; Max Acceleration (units/s2):
echo:  M201 X500.00 Y500.00 Z100.00 E5000.00
echo:; Acceleration (units/s2) (P<print-accel> R<retract-accel> T<travel-accel>):
echo:  M204 P500.00 R1000.00 T500.00
echo:; Advanced (B<min_segment_time_us> S<min_feedrate> T<min_travel_feedrate> J<junc_dev>):
echo:  M205 B20000.00 S0.00 T0.00 J0.08
echo:; Home offset:
echo:  M206 X0.00 Y0.00 Z0.00
echo:; Auto Bed Leveling:
echo:  M420 S0 Z40.00 ; Leveling OFF
echo:  G29 W I0 J0 Z-0.38000
echo:  G29 W I1 J0 Z-0.27500
echo:  G29 W I2 J0 Z-0.14250
echo:  G29 W I3 J0 Z-0.00250
echo:  G29 W I4 J0 Z0.09000
echo:  G29 W I0 J1 Z-0.34750
echo:  G29 W I1 J1 Z-0.24000
echo:  G29 W I2 J1 Z-0.11250
echo:  G29 W I3 J1 Z0.02250
echo:  G29 W I4 J1 Z-0.28250
echo:  G29 W I0 J2 Z-0.33750
echo:  G29 W I1 J2 Z-0.22000
echo:  G29 W I2 J2 Z-0.08500
echo:  G29 W I3 J2 Z0.04250
echo:  G29 W I4 J2 Z0.15750
echo:  G29 W I0 J3 Z-0.30250
echo:  G29 W I1 J3 Z-0.20250
echo:  G29 W I2 J3 Z-0.08500
echo:  G29 W I3 J3 Z0.02000
echo:  G29 W I4 J3 Z0.11750
echo:  G29 W I0 J4 Z-0.32750
echo:  G29 W I1 J4 Z-0.23000
echo:  G29 W I2 J4 Z-0.13250
echo:  G29 W I3 J4 Z-0.04500
echo:  G29 W I4 J4 Z0.04750
echo:; Material heatup parameters:
echo:  M145 S0 H150.00 B55.00 F0
echo:  M145 S1 H240.00 B90.00 F0
echo:; Hotend PID:
echo:  M301 P19.91 I1.30 D76.05
echo:; Z-Probe Offset:
echo:  M851 X-70.00 Y-8.00 Z-1.96 ; (mm)
When sending M503, my esp32 webserver can only display a few lines from the beginning and then jumps to the end.
echo:  M204 P500.00 R10851 X-70.00 Y-8.00 Z-1.96 ; (mm)
<travel-accel>):
echo:  M200 S0 D1.75
echo:  G21 ; (mm)
$ M503
This is my code(only task SerialRx task on second core):
#include <Arduino.h>
#include <WiFi.h>
#include <AsyncTCP.h>
#include <ESPAsyncWebServer.h>
#include "FS.h"
#include "SD_MMC.h"
#include "SPI.h"
#include "esp_camera.h"
#include "soc/soc.h"
#include "soc/rtc_cntl_reg.h"
#include "driver/rtc_io.h"
TaskHandle_t SerialRx;
AsyncWebServer server(80);
//Define
void configESPCamera() {
void initMicroSDCard() {
void addToLogFile(String message) {
void takeNewPhoto(String path) {
void initWiFi() {
void handleUpload(AsyncWebServerRequest *request, String filename, size_t index, uint8_t *data, size_t len, bool final) {
void sendReversedLog(AsyncWebServerRequest *request) {
  WRITE_PERI_REG(RTC_CNTL_BROWN_OUT_REG, 0);
  initWiFi();
  initMicroSDCard();
  configESPCamera();
  xTaskCreatePinnedToCore(
    SerialRxFunction, /* Funkce úkolu. */
    "SerialRx",       /* Název úkolu. */
    10000,            /* Velikost zásobníku úkolu. */
    NULL,             /* Parametr úkolu. */
    1,                /* Priorita úkolu. */
    &SerialRx,        /* Ukazatel na úkol pro sledování vytvořeného úkolu. */
    1);
server.on("/", HTTP_GET, [](AsyncWebServerRequest *request) {
server.begin();
  String path = "/photos/image" + String(pictureCount) + ".jpg";
  takeNewPhoto(path);
  pictureCount++;
  if (pictureCount == 2000) {
    pictureCount = 0;
  delay(delayTime);
#define BUFFER_SIZE 64
#define SERIAL_TIMEOUT 1000
void SerialRxFunction(void *pvParameters) {
  char buffer[BUFFER_SIZE + 1];
  int index = 0;
  Serial.setTimeout(SERIAL_TIMEOUT);
  for (;;) {
    if (Serial.available() > 0) {
      char incomingChar = Serial.read();
      if (incomingChar != '\n' && index < BUFFER_SIZE) {
        buffer[index++] = incomingChar;
        buffer[index] = '\0';
        logFile = SD_MMC.open("/logs/serial_log.txt", FILE_APPEND);
        if (logFile) {
          logFile.println(buffer);
          logFile.close();
        index = 0;
How are you interfacing with the Ender via the USB port? Looking at the circuit diagram of the Ender, it uses a CXH340G chip for the UART so I am guessing you might be "hijacking" its TX and RX pins?
Bear in mind that with no handshaking control, data loss is inevitable during long bursts.
Yes
Is there any possible solution? If I understand correctly the problem is that esp32 is "not fast" enough to process serial lines. Is there any device that can process these long messages from ch340 in the printer and then send them in smaller messages to esp32 cam?
Any ideas? Handshaking isn't available.
not sure if this is really the reason
your buffer-variable has 64 bytes.
depending on how much RAM your camera and the rest of your code is occupying it is possible to increase this number to - what do I know 512? , 1024? , 2048?
Sure.
Any kind of microcontroller that is able to receive at 115200 baud and has enough RAM to hold long messages. Example: a second ESP32
Changing the buffer size didn't help either. In the end I decided to use ESP3D instead of my own project.
