/tmp/arduino/sketches/B9C1DB1DFFF522B3993CFF15FBD487D0/sketch/GigaDisplayShieldIMU_original.ino.cpp.o: In function `setup':
/home/user/Arduino/GigaDisplayShieldIMU_original/GigaDisplayShieldIMU_original.ino:21: undefined reference to `img_arduinologo'
collect2: error: ld returned 1 exit status
exit status 1
Compilation error: exit status 1
I've checked that my cut-and-paste is identical to the original example (and therefore refrained from posting the source code here, sorry). What is the work around? Thanks.
This is telling you your code is trying to access the above but it does not exist. Without the source this is about the best I can do. It is highly possible this is being referenced from one of the include files. I use Linux as well and for me it works great.
Thanks for your reply. As mentioned in the note, I refrained from posting the source code because I provided a link to it.
FWIW, I understand the semantics of the error message but I am having some difficulty locating the corresponding API docs. Whatever I've found are either Doxygen output with no comments or code that ran on prior boards (but cannot be reproduced in the GIGA eco-system). The challenge is to understand the relation between the 1st parameter of the Display.image method/function and the LVGL pre-processor directives that store the .bin image file in a local variable.
Please do not duplicate your questions as doing so wastes the time and effort of the volunteers trying to help you as they are then answering the same thing in different places.
Please create one topic only for your question and choose the forum category carefully. If you have multiple questions about the same project then please ask your questions in the one topic as the answers to one question provide useful context for the others, and also you won’t have to keep explaining your project repeatedly.
Repeated duplicate posting could result in a temporary or permanent ban from the forum.
Could you take a few moments to Learn How To Use The Forum
I tried to compile it, and it does indeed not compile.
Beside that error, I get a ridiculous amount of warnings (I have set the Compiler Warnings to "All" in the preferences).
I am at a loss for words! My original issue (using a custom image with the IMU) has not been resolved. I was trying to explain the issue with granularity. It was interpreted as a duplicate issue. So I'll simply move on. Sorry.
