Fun with Enums
I was messing around with a project that scroll through several LCD displays, getting frustrated that I had to constantly update the field of contents of an enum when I wanted to debug a certain display output.
I worked out this little sort-of-scalable thingy I thought I would share:
enum MyEnum{
  FIRST,
  SECOND,
  /*THIRD,*/
  FOURTH,
  FIFTH,
  END_OF_OPTIONS
MyEnum myEnum = static_cast<MyEnum>(END_OF_OPTIONS - 1);
  int mode = static_cast<int>(myEnum);
  myEnum = static_cast<MyEnum>(++mode % END_OF_OPTIONS);
  switch (myEnum)
    case FIRST:
      Serial.println("first");
    case SECOND:
      Serial.println("second");
/*    case THIRD:
      Serial.println("third");
      break; */
    case FOURTH:
      Serial.println("fourth");
    case FIFTH:
      Serial.println("fifth");
maybe someone else will find it useful in a similar project.
thanks - that's a smart idea
myEnum = static_cast<MyEnum>(++mode >= END_OF_OPTIONS ? 0 : mode);
…will generate less code / be much faster.
Thanks. I was positive someone could improve it!
