First of all sorry for the comments in spanish, but I think it is easy to understand. In the code below I try to set a color detector as a background function a function that works at every time that doesn't depend on anything, but something is wrong I have made a lot of try but doesn't seem to work, and the other thing is interrupt the movements of ardumoto when fsrlectura detects a force I use ifs but it doesn't interrupt the ardumoto movements, I will be very thankful If you help me.
The code:
//Declaracion variables//
#include <Servo.h>
#include <ADJDS311.h>
#include <Wire.h>
int pwm_a = 3; //pin ardumoto//
int pwm_b = 11;//pin ardumoto//
int dir_a = 12;//pin ardumoto//
int dir_b = 13;//pin ardumoto//
int fsrPin = 0;//pin analogico para sensor de fuerza//fsr pin
int fsrlectura;//variable en de lectura de sensor de fuerza//
int sensorLed_pin = 2; //pin de led de Color Light Sensor Evaluation Board//
ADJDS311 colorSensor(sensorLed_pin);
Servo myservo; //declaracion de servos//
Servo myservo2;
Servo myservo3;
Servo myservo4;
Servo myservo5;
Servo myservo6;
//--------Declaracion de pines y posiciones-----//
void setup(){
colorSensor.init();
colorSensor.ledOn(); //LED de Color Light Sensor Evaluation Board
myservo.attach(10);
myservo2.attach(8);
myservo3.attach(9);
myservo4.attach(7);
myservo5.attach(5);
myservo6.attach(6);
myservo4.write(90);//posicion inicial//initial pos
myservo5.write(0);//posicion inicial//initial pos
myservo6.write(180);//poscion inicial//initial pos
colorSensor.calibrate();
pinMode(pwm_a, OUTPUT);//se declaran los pines de ardumoto como salida//ardumoto pins as output
pinMode(pwm_b, OUTPUT);//se declaran los pines de ardumoto como salida//
pinMode(dir_a, OUTPUT);//se declaran los pines de ardumoto como salida//
pinMode(dir_b, OUTPUT);//se declaran los pines de ardumoto como salida//
analogWrite(pwm_a, 60);
analogWrite(pwm_b, 60);
// Lo que TOB debe de hacer//
void loop(){
noInterrupts();
RGBC color = colorSensor.read(); //leen los colores read colors
Serial.print(color.red);//se imprime color rojo//
Serial.print(" | ");
Serial.print(color.green);//se imprime color verde//
Serial.print(color.blue);//se imprime color azul//
Serial.println(color.clear);
fsrlectura = analogRead(fsrPin);
Serial.print ("Lectura FSR = ");
Serial.print(fsrlectura);//se imprime lectura de sensor de fuerza//
delay(1100);
digitalWrite(dir_a, LOW); // movimients ardumoto.////movements of ardumoto)
digitalWrite(dir_b, LOW);// movimients ardumoto.//
delay(3000);
analogWrite(pwm_a, 60);// movimients ardumoto.//
analogWrite(pwm_b, 60);// movimients ardumoto.//
delay(3000);
digitalWrite(dir_a, HIGH);// movimients ardumoto.//
digitalWrite(dir_b, HIGH);// movimients ardumoto.//
delay(3000);
delay(2000);
//------------------------------------------------------------------this is the background function-------------------------------------------------//
if(color.red > 980 && color.green < 1000) { //----------------rojo-----// red
myservo.write(180);//si se detecta color rojo, abrir depsito AA//
else{
myservo.write(0);//si no no abrir//
if ( color.red < 500 && color.blue < 380 && color.clear < 330 && color.green > 350 && color.green <450){ //---------------verde----------// green
myservo2.write(90);//si se detecta color verde, abrir deposito de Cuadradas//
else{
myservo2.write(0);//si no no abrir//
if (color.red > 400 && color.red < 600 && color.blue > 260 && color.green < 1000){//----------azul------// blue
myservo3.write(90);//si se detecta color azul abrir deposito AAA//
else{
myservo3.write(0);//si no no abrir//
if (fsrlectura < 10){//si no hay fuerza en fsr mantener pinza en posicion inicial//if no force keep intial position
myservo4.write(90);
myservo5.write(0);
//---------------------------------Here I want to interrupt the ardumoto movemets when fsrlectura detects a force------------//
if (fsrlectura > 630 && fsrlectura < 690) {// ----------AAA// if detects a force do not move ardumoto
analogWrite(pwm_a, 0);
analogWrite(pwm_b, 0);
digitalWrite(dir_a, LOW);// Movements of ardumoto.
myservo4.write(120); //--------------this are just a secuence of servo movements, but for any reason I can't interrupt the ardumoto//
delay(1300);
myservo5.write(180);
delay(1300);
myservo6.write(0);
myservo6.write(0);
else{
myservo4.write(90); //--------------------if no force is detected keep initial pos and keep moving ardumoto-------//
myservo5.write(0);
delay(3000);
delay(3000);
delay(3000);
delay(2000);
if (fsrlectura > 400 && fsrlectura < 450){ //---------AA//
myservo5.write(20);
myservo4.write(0);
myservo6.write(0);
myservo6.write(0);
else{
myservo4.write(90);
myservo5.write(0);
delay(3000);
delay(3000);
delay(3000);
delay(2000);
if (fsrlectura > 300 && fsrlectura < 420) { //-------------9V//
myservo4.write(50);
myservo6.write(0);
myservo6.write(0);
else{
myservo4.write(90);
myservo5.write(0);
delay(3000);
delay(3000);
delay(3000);
delay(2000);
if (fsrlectura > 576) { //-------------D//
myservo4.write(145);
myservo5.write(30);
myservo6.write(0);
myservo6.write(0);
else{
myservo4.write(90);
myservo5.write(0);
delay(3000);
delay(3000);
delay(3000);
delay(2000);
