Function call errors
Hello all!
I am trying to learn C or C++, and I still have a problems as well as need a lot of help.
I am trying to adapt the GSM_Shield program to control a GSM module only to send and receive SMS, at the moment I am testing only the send command. I have to write another function to receive the response.
I have the following function call the I am testing:
digitalWrite(power_pin, HIGH); // Switch ON the GSM module
delay(2000):
char SendATCmdWaitResp("AT+CREG?", 1000, "\r\n+CREG:1,1\r\n\r\nOK\r\n");
char SendATCmdWaitResp(char const *AT_cmd_string, uint16_t time_out,
                char const *response_string)
  byte status;
  char ret_val = 0;
  byte i;
    Serial.println(AT_cmd_string);
      if(IsStringReceived(response_string)) {
        ret_val = AT_RESP_OK;
        break;  // response is OK => finish
      else ret_val = AT_RESP_ERR_DIF_RESP;
    else {
      // nothing was received
      ret_val = AT_RESP_ERR_NO_RESP;
  return (ret_val);
I have the following errors:
GSM_Control_Final.ino: In function void loop();
GSM_Control_Final:48: error: expression list treated as a compound expression in initializer[-fpermissivel]
GSM_Control_Final:48: error: invalid conversion from 'cost char to char' [-fpermissivel]
Your help is appreciated.
Thanks and regrads
Manuel
char const *
This maybe should be const char *
Michinyon,
Thanks for your prompt response and your help, but, changing from 'char const' to 'const char' didn't solve the problem.
Any help is wellcome.
Thanks.
Manuel
Are you trying to call the function with this line in the loop() function or define it ?
Hello UKHeliBob!
I am trying to call the function in the loop(). The function prototype is before the setup().
char SendATCmdWaitResp(const char *AT_cmd_string, uint16_t time_out,const char *response_string);
Thanks for reply.
Manuek
Then you have a naked "char" there at the function call. It returns a char and you do nothing with it. you need to assign it to a variable or use it some other way.
KeithRB,
thanks for your answer. I am stucked I can not get out of this problem. I assgned a variable like this:
char resp = 0;
I went to the function call the add this:
if (resp == char SendATCmdWaitResp("AT+CREG?", 1000, "\r\n+CREG:1,1\r\n\r\nOK\r\n"));
I still get the following error:
error: -expected primary_expression before 'char'
error: - expected a ')' before 'char'
That is not a function call.
This is:
char x = SendATCmdWaitResp("AT+CREG?", 1000, "\r\n+CREG:1,1\r\n\r\nOK\r\n");
Thanks to you all!
The problem was solved (wasn't a problem).
You do not believe, what was the problem for the function not printing. I forgot to include in setup() the function Serial.begin(115200);
Thanks again.
Manuel
Now you know why this sticky read this before posting a programming question tells you to post all of your program and not just snippets.
However, if you still have
in your program you are still not calling the function correctly.
