Function call not returning
I want to send various data from different sensors (data types) through serial port. But I am having a problem that after some time my function call never returns.
I made sequence diagram to depict you better what I am trying to implement:
Message sent through serial stream has the following format: |STX|Data Type|Data Length|Data|ETX, and is represented by Message class.
Message.h
http://textuploader.com/dkcvh
Message.cpp
http://textuploader.com/dkcvg
MessageEncoder.h
http://textuploader.com/dkcv7
MessageEncoder.cpp
http://textuploader.com/dkcv2
MessageSerialization.h
http://textuploader.com/dkcvu
MessageSerialization.cpp
http://textuploader.com/dkcn4
MessageProcessor.h
http://textuploader.com/dkcvn
MessageProcessor.cpp
http://textuploader.com/dkcvy
main.cpp
http://textuploader.com/dkcnr
I have checked MessageEncoder and MessageSerialzation methods and they work fine, problem is in MessageProcessor class. After MessageProcessor::processTransmitData method call in main, method returns normally, but after some time everything stops. I have figured out that the problem resides in last 3 lines of MessageProcessor::processTransmitData method
	delete encodedMessage;
	delete serializedBuffer;
Somehow program gets stuck after calling these delete functions. And I am almost sure it has something to do with memory allocation for encodedMessage and serializedBuffer pointers. serializedBuffer is allocated in MessageProcessor::processTransmitData method, and encodedMessage is allocated in MessageEncoder::encode method. I think that at some point, stackoverflow happens
you can see at the end of COM port at this picture that output gets stuck.
Am I correct to think your program is spread over those 9 files?
Sorry, I'm too lazy to read more than one (maybe 2 at a stretch). Can you make a simple example that illustrates the problem?
And your pictures are unreadable.
...R
Robin2:
...R
Yes there are over 9 files, but maybe if you had opened them you would had realised that they are short files with at most 30 lines of code. I wanted to make it more logical to me and to put different functionalities in different classes.
You can to click on the picture to enlarge it.
You somhow manage to corrupt the heap.
Deleting objects twice, overwriting memory via bad pointers or writing beyond array limits are some
of the common strategies to achieve that.
If you have a lot of heap activity you have many vulnerable spots (the control blocks in front of each
allocation) that are used unchecked in each new/delete.
I will not look at pictures of code scattered over 9 locations.
You have to only check:
I have already written that there lays a problem.
SimpleThings:
Yes there are over 9 files, but maybe if you had opened them ]
Like I said. I am lazy.
...R
You do not have to open 1 file and look at it but yet you have time to argue with me why you do not want to look at them, I guess this is the wrong place to ask a question.
Holy over-engineering Batman!
I've been a little more generous and looked at the files, but clickable links would have been nice.
  retVal == messageProcessor.processTransmitData(0x01, 4, data);
Oops.
#define MESSAGE_PROCESSOR_NOK -1
const char* MessageSerialization::serialize(Message* serialMessage)
	serializedBuffer = new uint8_t[serializedBufferLen];
	if ( serializedBuffer == NULL )
      return MESSAGE_SERIALIZATION_NOK;
int8_t MessageProcessor::processTransmitData(uint8_t dataType, uint8_t dataLength, uint8_t* dataBuffer)
	serializedBuffer = this->messageSerialization->serialize(encodedMessage);
	  return MESSAGE_PROCESSOR_NOK;
Returning MESSAGE_SERIALIZATION_NOK as an error pointer?
Message* MessageEncoder::encode(uint8_t dataType, uint8_t dataLength, uint8_t* dataBuffer)
	Message* encodedMessage = new Message(dataType, dataLength, dataBuffer);
	if ( encodedMessage == NULL )
		return NULL;
	return encodedMessage;
Why not simply:
	return new Message(dataType, dataLength, dataBuffer);
Or bet yet, dump the MessageEncoder class altogether, at least until you have things working.
const char* Message::getDataBuffer()
	returnDataBuffer = new uint8_t[this->dataLength + 1];
	memset(&returnDataBuffer[this->dataLength + 1], '\0', 1);
You are writing a byte beyond the end of the allocation.
Better: returnDataBuffer[this->dataLength] = '\0'
memcpy( &serializedBuffer[MESSAGE_DATA_START_INDEX], serialMessage->getDataBuffer(), serialMessage->getDataLength() );
Where do you delete the buffer allocated by serialMessage->getDataBuffer() ?
SimpleThings:
When I ask a question here (or in any other Forum) I take a great deal of trouble to minimize the effort needed by people who are kind enough to give their time to help me. You philosophy may be different.
...R
First of all arduarn thank you for you answer.
arduarn:
Oops.
Yeah copy pasted it and haven't even notice..., I fixed it now.
arduarn:
I agree it's not very descriptive I changed it to
 if ( encodedMessage == NULL)
  return MESSAGE_PROCESSOR_NULL_PTR;
Is that any better?
arduarn:
return NULL;
Why not simply:
I changed it the way you wrote, I simply forgot we can return objects/object pointers this way in C++ as we can do it in Java and C#
[/quote]
Ye I forgot that indexes do not start from 1 but from 0.
arduarn:
I changed it to
#include "MessageSerialization.h"
#include "Message.h"
uint8_t* tempDataBuffer;
tempDataBuffer = serialMessage->getDataBuffer();
memcpy( &serializedBuffer[MESSAGE_DATA_START_INDEX], tempDataBuffer, serialMessage->getDataLength() );
delete tempDataBuffer;
Now it works like a charm, thank you so much, I really appriciate that you took your time to help me.
SimpleThings:
Is that any better?
Not really, you still try to return -1 as a pointer... Where do you think it will point at?
And not C++11 has a better alternative for NULL in a pointer namely nullptr :slight_smile:
sry for double post
Robin2:
...R
I do not know what to tell you I tried my best. You had to look at 5 .cpp files ( with no of lines of code: 33 + 34 + 42 + 7 + 24), that's 140 lines of code. I tried to be as descriptive as much as possible in my first post.
septillion:
I forgot that it returns const char*, not int8_t ... I guess I should have made it returning int8_t as return value and instead giving a pointer to a buffer as a function parameter?
That's a possibility. Don't really know what you try to do. Can't you just return nullptr (/NULL) if it's an error or does that already have a different meaning?
septillion:
No returning NULL does not have any different meaning, I listened to your advice and put nullptr as return value. I just thought maybe it would be better to add integer as return value, perhaps if I want to add some other functionalities in this function and perhaps there will be a need to return some other error codes.
Things like that depend on your design. Advantage of returning nullptr in case of an error (or not needing to do anything) is that you only have to mess with a single (return) variable. Downside is you only have one error/inactive state (the nullptr) so you have no way of passing a description of for example the difference between error and just do nothing.
