opk
1
I'm writing function which consist of number of arrays however the function don't execute.
float vIns[18];
#define tacSwitch 2
#define xBase 5
float vL[18];
float iL[18];
float load[18];
float vcal = 4.640;
bool J = 1;
void setup(){
pinMode( vIns, INPUT);
pinMode(tacSwitch, INPUT_PULLUP);
pinMode(xBase, OUTPUT); }
void loop(){
J = digitalRead(tacSwitch); // is switch triggered? 1=NO 0 = yes
if(J == 0){
ircalc();
"void ircalc(){ //function is ircalc
digitalWrite(xBase, HIGH); //xBase is input pullup
for (int i=0; i<=17; i++){
vL[i] = (analogRead(vIns[i])*vcal)/1023; // vL is an array, vIns is an array
load[i]=5; //load is an array
for (int i=0; i=17; i++){
iL[i] = vL[i]/load[i]; //ilL is an array,
digitalWrite(xBase, LOW); "
if the xBase goes high then it remain high the rest of function don't run.
Your code is incomplete, and so cannot compile.
...which you forgot to post.
It's also not an installation or troubleshooting issue.
Not going well, is it?
Your topic was MOVED to its current forum category as it is more suitable than the original
Please post a complete sketch that illustrates the problem rather than an isolated snippet of code with no context
Whoops !
What will be the values of i in this for loop ?
opk
5
the analog readings from vIns array
If that is a reply to my post #4 then you have missed the point of my question
Let me put it another way.
How many iterations of the for loop will occur ?
opk
7
18 iterations should occur
Try this
for (int i = 0; i = 17; i++)
Serial.println(i);
opk
9
i try your suggestion in the setup its work however in the loop where i call a function "ircalc" it does not work.
if(J == 0){
ircalc();
Still oops
I don't imagine the compiler was happy about those double quotes.
So, why didn't you fix it?
Leaving the same bug in is just wasting time.
opk
14
the double quotes is not in the original code
What about the incorrect for loop ?
system
Closed
16
