Hi, danke schonmal für die Antworten!
Hier nochmal der komplette Code. Habe ich das mit dem Else so richtig verstanden?
#include<FastLED.h>
#include<AltSoftSerial.h>
#define NUM_LEDS_1 10
#define NUM_LEDS_2 10
// AltSoftSerial RX_PIN 9, TX_PIN 8
#define DATA_PIN_1 2
#define DATA_PIN_2 3
#define COLOR 0
#define GRADIENT 1
#define ANIMATION 2
#define FADE 3
#define DEV_A 0
#define DEV_1 1
#define DEV_2 2
#define NUM_PALETTES 7
int tasterPin = 44;
DEFINE_GRADIENT_PALETTE( RedOrangeColors_gp ) {
0, 255, 89, 0, 64, 255, 183, 0, 128, 255, 17, 0, 191, 255, 183, 0, 255, 237, 38, 3,
DEFINE_GRADIENT_PALETTE( BlueGreenColors_gp ) {
0, 0, 255, 102, 10, 0, 255, 102, 64, 0, 166, 255, 128, 0, 255, 191, 191, 0, 123, 255, 245, 5, 235, 78, 255, 5, 235, 78,
DEFINE_GRADIENT_PALETTE( MagentaColors_gp ) {
0, 221, 0, 255, 10, 221, 0, 255, 64, 89, 0, 255, 128, 255, 0, 72, 191, 102, 0, 255, 245, 235, 7, 201, 255, 235, 7, 201,
pinMode(tasterPin, INPUT);
class LED {
private:
/*const CRGBPalette16 p = RainbowColors_p;
const CRGBPalette16 palettes[] = {p};//, PartyColors_p, CloudColors_p, LavaColors_p, OceanColors_p, ForestColors_p, HeatColors_p};*/
CRGB *leds;
byte num;
CRGB dest = CRGB::White;
CRGB current = CRGB::Black;
byte state = FADE;
byte op = 0;
byte m = 0;
float phi = 0;
float phi2 = 0;
float lastphi = 0;
short cyc = 0;
bool active = true;
float sp = 1;
float opt1 = 1;
float opt2 = 1;
public:
LED(CRGB * _leds, byte _num) {
leds = _leds;
num = _num;
void TuerKontakt() {
if (digitalRead(tasterPin) == HIGH) {
fill_solid( leds, num, CRGB(50, 50, 50));
void setColor(CRGB color) {
if (!active) return;
current = color;
state = COLOR;
void setGradient(byte _op) {
phi = lastphi = 0;
op = _op;
state = GRADIENT;
void setAnimation(byte _op) {
phi = 0;
op = _op;
state = ANIMATION;
void sinelon() {
fadeToBlackBy( leds, num, opt1 * 10);
int pos = (int)((sin(phi2 * 2 * PI / 255) + 1) / 2.0 * num);
leds[pos] += CHSV( phi, 255, 192);
CRGBPalette16 getPalette(byte i) {
switch (i) {
case 0: return (CRGBPalette16) RainbowColors_p;
case 1: return (CRGBPalette16) PartyColors_p;
case 2: return (CRGBPalette16) RedOrangeColors_gp;
case 3: return (CRGBPalette16) BlueGreenColors_gp;
case 4: return (CRGBPalette16) MagentaColors_gp;
case 5: return (CRGBPalette16) CloudColors_p;
case 6: return (CRGBPalette16) ForestColors_p;
case 7: return (CRGBPalette16) HeatColors_p;
case 8: return (CRGBPalette16) LavaColors_p;
case 9: return (CRGBPalette16) OceanColors_p;
case 10: return (CRGBPalette16) RainbowStripeColors_p;
default: return (CRGBPalette16)RainbowColors_p;
CRGB leds1[NUM_LEDS_1];
CRGB leds2[NUM_LEDS_2];
unsigned long t;
long s = 0;
short c = 0;
CRGB readCol;
/* SoftwareSerial Serial(5, 4); */
AltSoftSerial btSerial;
LED *strip1;
LED *strip2;
FastLED.addLeds<WS2812B, DATA_PIN_1, GRB>(leds1, NUM_LEDS_1);//.setCorrection( 0xAFFFC0 );
FastLED.addLeds<WS2812B, DATA_PIN_2, GRB>(leds2, NUM_LEDS_2);
strip1 = new LED(leds1, NUM_LEDS_1);
strip2 = new LED(leds2, NUM_LEDS_2);
FastLED.show();
btSerial.begin(9600);
t = micros();
byte readByte() {
byte c = 0;
while (!btSerial.available()) {
delayMicroseconds(500);
c++;
if (c > 100) {
return 0;
return btSerial.read();
CRGB readColor() {
byte r = readByte();
byte g = readByte();
byte b = readByte();
return CRGB(r, g, b);
void handleInput() {
char c = btSerial.read();
/* Serial.println(c); */
if (c == 'c') {
CRGB c = readColor();
byte check = readByte();
if (check == ('c' + c.r + c.g + c.b) % 256) {
strip1->setColor(c);
strip2->setColor(c);
} else if (c == 'g') {
byte n = readByte();
if (check == ('g' + n) % 256) {
strip1->setGradient(n);
strip2->setGradient(n);
} else if (c == 'a') {
if (check == ('a' + n) % 256) {
strip1->setAnimation(n);
strip2->setAnimation(n);
} else if (c == 'f') {
if (check == ('f' + c.r + c.g + c.b) % 256) {
strip1->setFade(c);
strip2->setFade(c);
} else if (c == 'd') {
if (check == ('d' + n) % 256) {
if (n == 0) {
strip1->setActive(true);
strip2->setActive(true);
} else if (n == 1) {
strip2->setActive(false);
} else if (n == 2) {
strip1->setActive(false);
} else if (c == 'm') {
if (check == ('m' + n) % 256) {
strip1->setMode(n);
strip2->setMode(n);
} else if (c == 's') {
if (check == ('s' + n) % 256) {
strip1->setSpeed(n);
strip2->setSpeed(n);
} else if (c == 'o') {
if (check == ('o' + n) % 256) {
strip1->setOpt1(n);
strip2->setOpt1(n);
} else if (c == 'p') {
if (check == ('p' + n) % 256) {
strip1->setOpt2(n);
strip2->setOpt2(n);
void fps() {
int dt1 = micros() - t;
int wait = (16666 - dt1) / 1000;
if (wait > 0) delay(wait);
//delay(10);
s += micros() - t;
if (c == 0) {
/* Serial.println(100000000/s); */
s = 0;
c++;
c %= 100;
t = micros();
while (btSerial.available()) {
handleInput();
/* Serial.println("handleInput"); */
bool a = strip1->loop_1();
bool b = strip2->loop_1();
if (a || b) {
FastLED.show();
strip1->closeLoop();
strip2->closeLoop();
FastLED.show();
fps();
Diese Fehler haut er trotzdem noch raus:
led_control_slave:416:5: error: expected '}' at end of input
exit status 1
expected ';' after class definition
Sorry falls ich mich blöd anstelle xD
P.S. der gesamte Code ist zu lang zum einfügen, hab in der Mitte was von den Effekten rausgelöscht
