Function-definition is not allowed before '{' token error
The following code has an error on the right below the 5th line surrounded by "ppppppppppppp"s but we have a bracket there? Can you guys help?:
#include “U8glib.h” // Library for Oled display https://github.com/olikraus/u8glib/
#include “HX711.h” // Library for Load Cell amplifier board
volatile boolean TurnDetected; // variable used to detect rotation of Rotary encoder
volatile int Rotary_Flag=0; // flag to indicate rotation as occured
// Rotary Encoder Module connections
#define RotaryCLK 2 // Rotary encoder CLK pin connected to pin 2 of Arduino
#define RotaryDT 3 // Rotary encoder DT pin connected to pin 3
#define RotarySW 4 // Rotary encoder Switch pin connected to pin 4
// HX711 Module connections
#define CLK 5 // CLK of HX711 connected to pin 5 of Arduino
#define DOUT 6 // DOUT of HX711 connected to pin 6 of Arduino
//ppppppppppppppppppppppppppppppppppppppppp
#define Zawarudo 8 //This is for pin number 8
int reset_screen_counter=0; // Variable used to decide what to display on Oled
volatile int current_units=0; // Used to select which measuring unit to use (KG,Grams,Pounds)
float unit_conversion; // Used to convert between measuring units
int decimal_place; // how many decimal number to display
HX711 scale(DOUT, CLK); // Init of the HX711
U8GLIB_SSD1306_128X32 u8g(U8G_I2C_OPT_FAST); // Init of the OLED
// Interrupt routine runs if Rotation detected from Rotary encoder
void rotarydetect () {
Rotary_Flag=1; // Set Rotary flag from 0 to 1
// Used to change the measurement units (0=grams, 1=KG, 2=pounds)
void change_units () {
if (current_units == 0) current_units=1;
else if (current_units == 1) current_units=2;
else if (current_units == 2) current_units=0;
// Run at Startup and when Resetting with Rotary encoder switch
void startupscreen(void) {
u8g.setFont(u8g_font_unifont);
u8g.firstPage();
do {
u8g.drawStr( 0, 10, “Clear Scale”);
u8g.drawStr( 0, 28, “Click to zero…”);
} while( u8g.nextPage() );
// Reset Scale to zero
void tare_scale(void) {
scale.set_scale(-81500); //Calibration Factor obtained from calibration sketch
scale.tare(); //Reset the scale to 0
// Start Displaying information on OLED
void start_scale(void) {
char temp_current_units[15]; // Needed to store String to Char conversion
String KG=“KG”;
String GRAMS=“GRAMS”;
String LBS=“POUNDS”;
if (current_units == 0) { // 0 = grams
GRAMS.toCharArray(temp_current_units, 15); // Convert String to Char for OLED display
unit_conversion=1000; // conversion value for grams
decimal_place=0; // how many decimal place numbers to display
} else if (current_units == 1) { // 1 = Kilograms
KG.toCharArray(temp_current_units, 15);
unit_conversion=1;
decimal_place=3;
} else { // else 2 = Pounds
LBS.toCharArray(temp_current_units, 15);
unit_conversion=2.2046226218;
decimal_place=3;
u8g.firstPage();
do {
u8g.drawStr( 0, 10, temp_current_units); // Display the current measurement unit
u8g.setPrintPos(38, 28);
u8g.print(scale.get_units(3)*unit_conversion, decimal_place); // Display the average of 3 scale value reading
void setup(void) {
// Set pinmode for Rotary encoder pins
pinMode(RotarySW,INPUT_PULLUP);
pinMode(RotaryCLK,INPUT_PULLUP);
pinMode(RotaryDT,INPUT_PULLUP);
// Attach interrupt 0 (Pin 2 on UNO) to the Rotary Encoder
attachInterrupt (0,rotarydetect,RISING); // interrupt 0 always connected to pin 2 on Arduino UNO
// Rotate screen 180 degrees on OLED, if required
u8g.setRot180();
// Set color of OLED to Monochrome
u8g.setColorIndex(1);
// Select font to use
String start_count_string=“Hello Friend…”; // Message to display at Startup
char start_count[15]; // Used to String to Char conversion
// Loop to display counting dots
for (int x=12; x < 16; x++) { // Select the first 12 to 16 character of String
start_count_string.toCharArray(start_count, x);
u8g.firstPage();
do {
u8g.drawStr( 0, 10, “ARDUINO SCALE”);
u8g.drawStr( 0, 28, start_count);
delay(500); // Delay between dots
void loop(void) {
//pppppppppppppppppppppppppppppppppppppppppppp
void Threshold () {
if (current_weight > 0)
digitalWrite(Zawarudo,HIGH);
digitalWrite(Zawarudo,LOW);
// pppppppppppppppppppppppppppppppppppppppppppp
// If Switch is pressed on Rotary Encoder
if (!digitalRead(RotarySW)) { // Check to see which action to take
if(reset_screen_counter == 1) {
tare_scale(); // 1 = zero and start scale
reset_screen_counter=2;
if(reset_screen_counter == 2) { // 2 = Scale already started so restart from begining
// If Rotation was detected
if (Rotary_Flag == 1) {
change_units(); // change the measuring units
Rotary_Flag=0; // reset flag to zero
// If system was just started display intro screen
if (reset_screen_counter == 0) {
startupscreen();
reset_screen_counter=1; // set to 1 and wait for Rotary click to zero scale
// if zero (tare) of scale as occured start display of weight
if (reset_screen_counter == 2) {
start_scale();
void loop(void) {
 void Threshold ()  {
You can’t embed a function definition inside another function.
Please remember to use code tags when posting code
This isn’t an installation or troubleshooting question.
void loop(void) {
Should be
void loop(void) {}
