function-definition is not allowed here before '{' token ERROR
Hi everyone,
I am facing the error in programming of ultrasonic radar system.
The error is,
function-definition is not allowed here before ‘{’ token ERROR
Pls pls help me out with a modified code…
thank u so much…
radar.txt (1.38 KB)
For starter
  myServo.attach(10); // Pin Connected To Servo
is outside setup().
There might be more wrong.
(deleted)
pinMode(echoPin, INPUT); // echoPin as an Input
  }  // this curly bracket is in the wrong place.
The misplaced curly bracket ends the setup function early. Move that curly bracket to the end of the setup code like so:
}  // this is where the bracket belongs
alright, this is the only error i am facing and this only the full code.
apologize if i wrote something wrong
Hey I am sharing you the screenshot pls pls respond..
Screenshots are worthless. Read the posting guidelines here.
I don't see a screenshot.
And if it shows code or errors or serial monitor, don't bother. Copy and paste here using code tags (or, in case to big, attach it).
Remember two things: The only thing allowed outside of a function is a variable or function declaration. Functions cannot be declared inside a function.
Hi, PLEASE, PLEASE, PLEASE
Please read the first post in any forum entitled how to use this forum. http://forum.arduino.cc/index.php/topic,148850.0.html then look down to item #7 about how to post your code. It will be formatted in a scrolling window that makes it easier to read.
Thanks.. Tom... :o
