Hey out there!
I really got problems with Arduino. Now that I've managed to finally find the right port and make a LED blink using a Winows Computer and not my Mac I have trouble making a void flash command. It worked on my Mac and I'm just doing the same thing, but I don't know why it's not working. After compiling I just get the error-message "a function definition is not allowed here before '{' token". I've already moved several parts of the code, but only get other error messages. Maybe you can have a look at the code and help me? It's a screenshot in the attachments. Please use easy english, as I'm german.
There's no closing "}" for the loop() function, only for the for loop in it
There is a closing '}' for the loop, its just way down so you can't see it on the screenshot.
Post all of your code, not a screen shot. And please use code tags.
And please post the full error message.
Sorry.
Here's the full code:
int ledPin = 12;
pinMode(ledPin, OUTPUT);
void loop ()
void flash (int duration)
{ digitalWrite (ledPin, HIGH);
delay (duration);
digitalWrite (ledPin, LOW);
delay (duration);
delay (duration);
delay (duration);
delay (duration);
delay (duration);
for (int iCounter = 0; iCounter <= 100; iCounter++)
flash(200);
flash(500);
flash(200);
delay (5000);
What are code tags?
The full error message:
CodeFlash.ino: In function 'void loop()':
CodeFlash:12: error: a function-definition is not allowed here before '}' token is given
CodeFlash:28: error: 'flash' was not declared in this scope
Remove the flash function and place it after the void loop(){...} function.
Have you read the notice at the top of the board on how to use the forum?
dannable:
True, you can't have nested functions in C/C++.
igendel,
The code listing didn't match the screen shot so who knows what's happening!
dannable:
igendel,The code listing didn't match the screen shot so who knows what's happening!
Yes, well, one bug at a time ![]()
#include "Servo.h"
Servo servo;
#define IN1 8
#define IN2 9
#define IN3 10
#define IN4 11
int koraci = 0;
boolean smjer = true;
unsigned long vrijemeZadnje = 0; // biljeziti cemo vrijeme
unsigned long vrijemeTrenutno = 0; // koje je potrebno da se
unsigned long vrijeme = 0; // se izvrsi zadani kut
int koraciPreostalo = 4095; //ovaj koracni ukupno ima 4095 koraka
int poz = 0;
const int trig = 6; // Trig na PIN11
const int echo = 5; // Echo na PIN12
int led1 = 3;
int led2 = 4;
servo.attach(2); // signalni PWM pin Croduina je 9
pinMode(led1, OUTPUT);
pinMode(led2, OUTPUT);
pinMode(trig, OUTPUT);
pinMode(echo, INPUT);
Serial.begin(115200); // zapocinjem serijsku komunikaciju
pinMode(IN1, OUTPUT);
pinMode(IN2, OUTPUT);
pinMode(IN3, OUTPUT);
pinMode(IN4, OUTPUT);
Serial.println("Mjerenje udaljenost s HC-SR04 senzorom");
Serial.println("");
long vrijeme, udaljenost;
digitalWrite(trig, HIGH); // Slanje triga
delayMicroseconds(10); // Odaslani trig traje 10 μs = 0.1 ms
digitalWrite(trig, LOW);
vrijeme = pulseIn(echo, HIGH); // Primanje reflektiranog triga
udaljenost = (vrijeme/2) / 28; // Racunanje udaljenosti, u centimetrima
// konacna udaljenost senzora od predmeta
// u cm je varijabla "udaljenost"
Serial.print(udaljenost);
Serial.println(" cm");
delay(50); // preporucena pauza izmedu ocitanja ne bi trebala biti manja od 50ms
if(udaljenost <= 25){
digitalWrite(led1, HIGH); // pali se pocetkom dizanja donja led rasvijeta
while(koraciPreostalo > 0) // dokle je preostalo koraka do punog okreta
vrijemeTrenutno = micros(); //zapisi trenutno vrijeme u micro sek
if(vrijemeTrenutno - vrijemeZadnje >= 1000)
vrijeme = vrijeme + micros() - vrijemeZadnje;
vrijemeZadnje = micros();
koraciPreostalo--;
delay(50);
for(poz = 0; poz < 180; poz += 1) // motor se okrece od 0 do 180 stupnjeva
{ // u koracima od 1 stupnja
servo.write(poz); // kazemo servo da provjeri varijablu poz za poziciju
// cekamo 15ms da motor dode na zadanu poziciju
delay(2000); //nakon 5 sekundi
digitalWrite(led2, HIGH); // pali se gornja led rasvijeta
else {
digitalWrite(led2, LOW); // gasi se gornja led rasvijeta
smjer = !smjer; // obrni smjer
koraciPreostalo = -4095;
while(koraciPreostalo < 0) // dokle je preostalo koraka do punog okreta
koraciPreostalo++;
for(poz = 180; poz>=0; poz-=1){
servo.write(poz);
delay(50);
delay(2000); //nakon 2 sekundi
digitalWrite(led1, LOW); // gasi se donja led rasvijeta
void stepper(int brojKoraka){
for (int x=0; x < brojKoraka; x++){
switch(koraci){
case 0:
digitalWrite(IN1, LOW);
digitalWrite(IN2, LOW);
digitalWrite(IN3, LOW);
digitalWrite(IN4, HIGH);
case 1:
digitalWrite(IN3, HIGH);
case 2:
digitalWrite(IN4, LOW);
case 3:
digitalWrite(IN2, HIGH);
case 4:
case 5:
digitalWrite(IN1, HIGH);
case 6:
case 7:
default:
postaviSmjer();
void postaviSmjer()
if(smjer==1){ koraci++; }
if(smjer==0){ koraci--; }
if(koraci>7){ koraci=0; }
if(koraci<0){ koraci=7; }
Error is "a function-definition is not allowed here before '{' token." for function" void stepper(int brojKoraka){ ". I tried many, many times but I didn't fix it. Can you put this code in your arduino IDE and fix it? Thank you very much!!!
nikolakristic:
#include "Servo.h"
Servo servo;
#define IN1 8
#define IN2 9
#define IN3 10
#define IN4 11
int koraci = 0;
int poz = 0;
int led1 = 3;
int led2 = 4;
Serial.println("");
udaljenost = (vrijeme / 2) / 28; // Racunanje udaljenosti, u centimetrima
if (udaljenost <= 25) {
while (koraciPreostalo > 0) // dokle je preostalo koraka do punog okreta
if (vrijemeTrenutno - vrijemeZadnje >= 1000)
koraciPreostalo--;
delay(50);
for (poz = 0; poz < 180; poz += 1) // motor se okrece od 0 do 180 stupnjeva
else {
while (koraciPreostalo < 0) // dokle je preostalo koraka do punog okreta
koraciPreostalo++;
for (poz = 180; poz >= 0; poz -= 1) {
servo.write(poz);
delay(50);
void stepper(int brojKoraka) {
for (int x = 0; x < brojKoraka; x++) {
switch (koraci) {
case 0:
case 1:
case 2:
case 3:
case 4:
case 5:
case 6:
case 7:
default:
postaviSmjer();
void postaviSmjer()
if (smjer == 1) {
koraci++;
if (smjer == 0) {
koraci--;
if (koraci > 7) {
koraci = 0;
if (koraci < 0) {
koraci = 7;
Hi there, now we have a problem. Function-definition is not allowed here before '{' token is not resolved. We have the code to see.
#include <SoftwareSerial.h>
SoftwareSerial SIM900 (0,1);
char inchar;
boolean lockLow = true;
boolean takeLowTime;
boolean Check_PIR;
int CalibrationTime = 30;
int led = 13;
int sensor = 3;
int sensor_Value;
int buzzer = 9;
int sms_count = 0;
pinMode(led, OUTPUT);
digitalWrite(led, LOW);
pinMode(buzzer, OUTPUT);
digitalWrite(buzzer, LOW);
pinMode(sensor, INPUT);
digitalWrite(sensor, LOW);
pinMode(9, OUTPUT);
digitalWrite(9, LOW);
delay(100);
digitalWrite(9, HIGH);
delay(2500);
Serial.print("Calibrating Sensor");
for(int i = 0; i<CalibrationTime; i++)
Serial.print(".");
Serial.print("done");
Serial.println("SENSOR ACTIVE");
delay(50);
SIM900.begin(9600);
SIM900.println("AT+CMGF=1");
delay(200);
if(digitalRead(sensor) == HIGH)
digitalWrite(led, HIGH);
if(lockLow)
lockLow = false;
Serial.println("-----");
Serial.println ("detectd at");
delay(50);
if(digitalRead(sensor) == LOW)
digitalWrite(buzzer, HIGH);
if(takeLowTime)
takeLowTime = false;
lockLow=true;
Serial.print("ended at ");
delay(50);
Serial.println(sensor_Value);
Serial.println(sms_count);
void Check_SMSReceive()
SIM900.println("AT+CNMI= 2,2,0,0,0");
delay(200);
Serial.println("Waiting for SMS.....");
delay(200);
if(SIM900.available() >0)
inchar=SIM900.read();
if (inchar=='*')
delay(10);
if (inchar=='o')
delay(10);
if (inchar=='n')
delay(900);
Serial.println( "Message received to Activate Alarm" );
SIM900.println("AT+CMGD=1,4");
void Check_PIR()
sensor_value=digitalRead(sensor);
if((sensor_value==HIGH) && (sms_count < 1))
digitalWrite(buzzer,HIGH);
delay(2000);
digitalWrite(buzzer,LOW);
SendTextMessage();
void SendTextMessage()
delay(200);
SIM900.println("AT+CMGS="0962143035"\r");
delay(200);
SIM900.println("Movement detected");
Serial.println( "Movement detected" );
delay(200);
SIM900.println((char)26);
delay(200);
sms_count++;
Please see my please.
Where does loop() end?
Please remember to use code tags blah blah blah
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
Thanks.. Tom.. ![]()
i have a similar problem, i tried to change everything i think that could be wrong but still not works!.
BIOS2.INO:
//Include Section
//Keyboard Files
#include <PS2Keyboard.h>
//TV Output Files
#include <TVout.h>
#include <font4x6.h>
#include <font6x8.h>
#include <font8x8.h>
#include <font8x8ext.h>
#include <fontALL.h>
#include "logo.h"
//Program Files
#include "hcmd2.h"
/* 0 = DEC 48
* 1 = DEC 49
* 2 = DEC 50
* 3 = DEC 51
* 4 = DEC 52
* 5 = DEC 53
* 6 = DEC 54
* 7 = DEC 55
* 8 = DEC 56
* 9 = DEC 57
PS2Keyboard Key;
TVout TV;
char KeyRead;
char KeyBuffer;
bool loopContinue;
//pinMode(4,INPUT);
//pinMode(5,INPUT);
TV.begin(NTSC,128,64);
TV.select_font(font4x6);
delay(100);
TV.bitmap(TV0.hres()/2,TV0.vres()/2,logo);
TV.clear_screen();
TV.println("COPYRIGHT H4CK SOFTWARE 2017-2019");
delay(100);
TV.println("FourBIOS V1.02");
delay(100);
TV.print("Starting Up: ");
TV.print(".");
TV.print(".");
TV.println(".");
Key.begin(2,3);
RESET0:
TV.print("HCMD:/>");
RESET1:
loopContinue = true;
while (loopContinue == true){
if (Key.available()) {
KeyRead = Key.read();
if (KeyRead == PS2_ENTER) {
cmdProcess(KeyBuffer);
loopContinue = false;
}else{
KeyBuffer = KeyRead;
TV.print(KeyRead);
TV.println(" < Execute?");
Error:
exit status 1
i attach the original files if that can help.
don´t mind me, problem solved!
BIOS2.ino (1.4 KB)
hcmd2.h (3.77 KB)
logo.cpp (5.32 KB)
logo.h (109 Bytes)
Life Lesson!
I forgot to close the void cmdProcess() function that is declared in hcmd2.h
So Don't mind me.
