Function-definition is not allowed PROBLEM
Hi
I'm having this error
error: a function-definition is not allowed here before '{' token
This is the code..where am i wrong?
Thanks!
#define MD 10 // Enable Pin for motor 1
#define MS 11 // Enable Pin for motor 2
#define I1 8 // Control pin 1 for motor 1
#define I2 9 // Control pin 2 for motor 1
#define I3 12 // Control pin 1 for motor 2
#define I4 13 // Control pin 2 for motor 2
pinMode(MS, OUTPUT);
pinMode(MD, OUTPUT);
pinMode(I1, OUTPUT);
pinMode(I2, OUTPUT);
pinMode(I3, OUTPUT);
pinMode(I4, OUTPUT);
void spegni()
digitalWrite(I1, LOW);
digitalWrite(I2, LOW);
digitalWrite(I3, LOW);
digitalWrite(I4, LOW);
void dritto()
//DIREZIONE DRITTA 5S
analogWrite(MS, 255); // Run in full speed
analogWrite(MD, 255); // Run in full speed
digitalWrite(I1, HIGH);
digitalWrite(I3, HIGH);
delay(5000);
void giraDX()
//GIRA A DX
void destra() {
digitalWrite(I3, LOW;
digitalWrite(I4, HIGH);
delay(2000);
void giraSX()
analogWrite(MD, 0); // Don't run
digitalWrite(I2, HIGH);
delay(2000);
//DIREZIONE RETRO 5S
void retro()
delay(5000);
if(Serial.available ())
scelta=Serial.read()
switch int(scelta)
case 1:
dritto();
spegni():
case 2:
retro();
spegni():
case 3:
giraDX();
spegni():
case 4:
giraSX();
spegni():
    void destra() {What are you trying to do here ?
What you are actually doing is to define a function but you cannot do that inside another function such as giraDX()
