Hello, I see there are other threads about this, but I wasn't sure if resurrecting years-old threads is a bad thing or not.
So clearly I have a syntax error. but I've checked every brace, bracket, and parenthisis and all over google but beating my head over it isn't helping, so I was hoping for some new eyes.
Entire code:
#include <WiFiNINA_Generic.h>
#include <SPI.h>
#include "arduino_secrets.h"
#include <hd44780.h>
#include <Wire.h>
#include <hd44780ioClass/hd44780_I2Cexp.h> // include i/o class header
int sensorPin0 = A0;
int sensorPin1 = A1;
int sensorValue0;
int sensorValue1;
int limit = 380;
hd44780_I2Cexp lcd;
lcd.init(); // initialize the lcd
// set up the LCD's number of columns and rows:
lcd.begin(20, 4);
lcd.backlight();
while (!Serial)
; // wait for serial port to connect. Needed for native USB port only
pinMode(13, OUTPUT);
pinMode(12, OUTPUT);
// check for the WiFi module:
if (WiFi.status() == WL_NO_MODULE)
Serial.print("Communication with WiFi failed!");
lcd.setCursor(0, 0);
lcd.print("Communication with");
lcd.setCursor(0, 1);
lcd.print("WiFi failed!");
// don't continue
while (true);
String fv = WiFi.firmwareVersion();
if (fv < WIFI_FIRMWARE_LATEST_VERSION)
Serial.print("Please upgrade the firmware");
lcd.setCursor (0, 0);
lcd.print("Please upgrade");
lcd.setCursor (0, 1);
lcd.print("the firmware");
sensorValue0 = analogRead(sensorPin0);
sensorValue1 = analogRead(sensorPin1);
Serial.print("Analog Value : ");
Serial.print(sensorValue0);
Serial.print(sensorValue1);
lcd.print(" ");
lcd.print("Analog Value : ");
lcd.print(sensorValue0);
lcd.setCursor (0, 2);
lcd.print(sensorValue1);
if (sensorValue0 < limit || sensorValue1 < limit)
digitalWrite(13, HIGH);
digitalWrite(12, HIGH);
digitalWrite(13, LOW);
digitalWrite(12, LOW);
// attempt to connect to WiFi network:
while (status != WL_CONNECTED)
Serial.print("Attempting to connect to WPA SSID: ");
lcd.print("Attempting to ");
lcd.print("WPA SSID: ");
Serial.print(ssid);
lcd.print(ssid);
lcd.setCursor (0, 3);
delay (2000);
// Connect to WPA/WPA2 network:
status = WiFi.begin(ssid, pass);
// wait 5 seconds for connection:
delay(5000);
pingResult = WiFi.ping(hostName);
if (pingResult >= 0)
Serial.print("SUCCESS! RTT = ");
Serial.print(pingResult);
Serial.print(" ms");
lcd.print("SUCCESS! RTT = ");
lcd.print(pingResult);
lcd.print(" ms");
Serial.print("FAILED! Error code: ");
lcd.print("FAILED! Error code: ");
lcd.setCursor(1, 1);
void printWiFiData()
// print your board's IP address:
IPAddress ip = WiFi.localIP();
Serial.print("IP address : ");
Serial.print(ip);
lcd.print("IP address : ");
lcd.print(ip);
// you're connected now, so print out the data:
Serial.print("You're connected to the network");
lcd.print("You're connected to ");
lcd.print("the network");
delay (2000);
lcd.print(" ");
printCurrentNet();
printWiFiData();
Serial.print("Subnet mask: ");
Serial.print((IPAddress)WiFi.subnetMask());
Serial.print("Gateway IP : ");
Serial.print((IPAddress)WiFi.gatewayIP());
// print your MAC address:
byte mac[6];
WiFi.macAddress(mac);
Serial.print("MAC address: ");
void printCurrentNet()
// print the SSID of the network you're attached to:
Serial.print("SSID: ");
Serial.print(WiFi.SSID());
// print the MAC address of the router you're attached to:
byte bssid[6];
WiFi.BSSID(bssid);
Serial.print("BSSID: ");
// lcd.print("BSSID: ");
// lcd.print('/n');
// printMacAddress(bssid);
//print the received signal strength:
//long rssi = WiFi.RSSI();
Serial.print("signal strength (RSSI): ");
Serial.print(rssi);
//print the encryption type:
byte encryption = WiFi.encryptionType();
Serial.print("Encryption Type: ");
Serial.print(encryption, HEX);
Serial.print();
//void printMacAddress(byte mac[])
// for (int i = 5; i >= 0; i--)
// if (mac[i] < 16)
// Serial.print("0");
// // lcd.print("0");
// // lcd.print('/n');
// Serial.print(mac[i], HEX);
// if (i > 0)
// Serial.print(":");
// // lcd.print(":");
and the two parts that result in a " function-definition is not allowed here before '{' token "
are:
Serial.print(ip);
lcd.print(ip);
delay (2000);
lcd.print(" ");
printCurrentNet();
printWiFiData();
byte mac[6];
byte bssid[6];
WiFi.BSSID(bssid);
// lcd.print('/n');
Serial.print(rssi);
Serial.print();
If I comment those out the rest compiles. I figure this will be something stupid, but I tried all the stupid things I can think of.
Thanks
