Hello people
I am making an arduino watch with an LCD 20x4, I am having problems with the setds3231 function of setting the clock, it does not work the code part to increment or decrement the date and time.
I’ve done several tests but it still doesn’t work, I don’t know what I’m doing wrong so it doesn’t work
I thank you for your help
#include <Wire.h>
#include <TimerOne.h>
LiquidCrystal_I2C lcd(0x27, 20, 4);
#include "RTClib.h"
RTC_DS3231 RTC;
#define up 53
#define doow 51
#define set 12
#define set1 49
#define ok 10
int year1=0,month1=0,day1=0,hour1=0,minute1=0,second1=0;
char x[]={">"};
byte buttonState = 0;
int lastButtonState;
byte flag=0;
String zero(int n) {
if (n < 10) {
return "0" + String(n);
return String(n);
void Print_lcd();
void set_DS3231();
lcd.backlight();
lcd.init();
RTC.adjust(DateTime(__DATE__, __TIME__));
pinMode(up, INPUT_PULLUP);
pinMode(doow, INPUT_PULLUP);
// initialize the pushbutton pin as an INPUT_PULLUP:
pinMode(ok, INPUT_PULLUP);
pinMode(set, INPUT_PULLUP);
pinMode(set1, INPUT_PULLUP);
//DateTime nowr = RTC.now();
// year1= nowr.year(),month1= nowr.month(),day1 = nowr.day(),hour1 = nowr.hour(),minute1 = nowr.minute(),second1 = nowr.second();
buttonState = digitalRead(set1);
if (!buttonState && lastButtonState )
flag = flag + 1;
if (flag > 1) {
flag = 0;
lcd.clear();
lastButtonState=buttonState;
if (flag==0)
Print_lcd();
set_DS3231();
void set_DS3231()// Clock Set Function
static unsigned int menu2 = 0;
static unsigned int presse = 0;
int presse1=1,presse2=1;
unsigned int ds3231[6]={year1,month1,day1,hour1,minute1,second1};
lcd.setCursor(0,0);
lcd.print(" ");
lcd.setCursor(5,0); //
lcd.print("Set.Ds3231"); //
lcd.setCursor(0,1); //
lcd.print("Year"); //
lcd.setCursor(0,2);
lcd.print("Mon"); //
lcd.setCursor(0,3);
lcd.print("Day");
lcd.setCursor(10,1);//
lcd.print("Hour"); //
lcd.setCursor(10,2);
lcd.print("Min"); //
lcd.setCursor(10,3);
lcd.print("Sec");
presse2 = (digitalRead(set));
if (!presse2 && presse1 )
menu2 = menu2 + 1;
if (menu2 > 6) {
menu2 = 0;
presse1 = presse2;//
switch (menu2) {
case 0:
lcd.setCursor(4,1);
lcd.print(x[0]);
lcd.setCursor(5,1);
lcd.print(ds3231[menu2]);//year
case 1:
lcd.setCursor(4,1);
lcd.print(" ");
lcd.setCursor(4,2);
lcd.print(x[0]);
lcd.setCursor(7,2);
lcd.print(zero(ds3231[menu2])); //month
case 2:
lcd.setCursor(4,2);
lcd.print(" ");
lcd.setCursor(4,3);
lcd.print(x[0]);
lcd.setCursor(7,3);
lcd.print(zero(ds3231[menu2]));//day
case 3:
lcd.setCursor(4,3);
lcd.print(" ");
lcd.setCursor(15,1);
lcd.print(x[0]);
lcd.setCursor(17,1);
lcd.print(zero(ds3231[menu2]));//hour
case 4:
lcd.print(" ");
lcd.setCursor(15,2);
lcd.print(x[0]);
lcd.setCursor(17,2);
lcd.print(zero(ds3231[menu2]));//minute
case 5:
lcd.print(" ");
lcd.setCursor(15,3);
lcd.print(x[0]);
lcd.setCursor (17,3);
lcd.print(zero(ds3231[menu2]));//second
default:
lcd.print(" ");
menu2=0;
if (digitalRead(up)==LOW )
presse=ds3231[menu2];
presse+=1;
ds3231[menu2]=presse;
if (digitalRead(doow)==LOW )
presse-=1;
if (digitalRead(ok)==LOW)
RTC.adjust(DateTime(ds3231[0],ds3231[1],ds3231[2],ds3231[3],ds3231[4],ds3231[5]));
flag=0;
menu2=0;
lcd.clear();
delay(100);
void Print_lcd()
lcd.setCursor(0, 0);
//lcd.print("date:");
lcd.print(zero(nowr.day()) + "/" + zero(nowr.month()) + "/" + nowr.year());
lcd.setCursor(12, 0);
//lcd.print("time:");
lcd.print(zero(nowr.hour()) + ":" + zero(nowr.minute()) + ":" + zero(nowr.second()));
lcd.clear();
delay(10);
