Hello
I am using a v1.0 SEEEDSTUDIO CANBUS Shield attached to a UNO R3
using IDE 1.0.5, I have uploaded the receive_check program which compiles and uploads correctly. I don't have any other device to read the CAN off at this stage.
When i try to upload the send program however, it will not compile. Nor will it compile in v1.0 of the IDE either.
The same message appears in both
// demo: CAN-BUS Shield, send data
#include <mcp_can.h>
#include <SPI.h>
MCP_CAN CAN(10); // Set CS to pin 10
START_INIT:
if(CAN_OK == CAN.begin(CAN_500KBPS)) // init can bus : baudrate = 500k
Serial.println("CAN BUS Shield init ok!");
Serial.println("CAN BUS Shield init fail");
Serial.println("Init CAN BUS Shield again");
delay(100);
goto START_INIT;
unsigned char stmp[8] = {0, 1, 2, 3, 4, 5, 6, 7};
// send data: id = 0x00, standrad flame, data len = 8, stmp: data buf
CAN.sendMsgBuf(0x00, 0, 8, stmp);
delay(100); // send data per 100ms"
The error I get is this:
send.cpp: In function 'void loop()':
send:29: error: no matching function for call to 'MCP_CAN::sendMsgBuf(int, int, int, unsigned char [8])'
/Users/MH/Documents/Arduino/libraries/CAN_BUS_Shield_master/mcp_can.h:102: note: candidates are: byte MCP_CAN::sendMsgBuf(long unsigned int, byte, byte, byte, byte*)
Now I'm new to Arduino & programming, but am I right in thinking the IDE is telling me that function sendMsgBuf, needs to have five elements rather than the usual four for a can signal?
In testing this, the sketch compiles if I add an additional digit, for example:
CAN.sendMsgBuf(0x00, 0, 8, 0, stmp);
This then uploads fine, but the TX & RX red lights are on solid, and the serial monitor doesn't display anything apart from INIT OK, although i guess thats expected as nothing is telling stmp to print to serial.
Could anyone help with why the TX & RX lights are on solid, and how I could test that this board is actually outputting any signals once per second, back to the serial monitor?
Thanks
