Function fails rather spectacularly, I don't know how to describe it.
This code is trying to find digipot settings to get an enhanced current limiting diode to work (varying the resistance of a resistor varies the current with this design. The ultimate goal is two arrays holding the step settings for each digipot. I'm using two digipots, one 50 kOhm and one 10 kOhm ("digipot50" and "digipot10") http://www.microchip.com/wwwproducts/Devices.aspx?dDocName=en010498
SPIfunction is used for writing values to my devices, it works perfectly.
I is the current per circuit I'm looking for.
This is one point where it's breaking: currentMap50[k]=1.001*currentMap50[k-1];
It doesn't like the rewriting of currentMap50[k] in particular, regardless of what's on the right.
Then it also fails with this condition: while((currentMap50[m]-(i+1)*I) < 0)
Changing that to while (m<60) or similar makes it work.
Curiously, I have those twice in this function but only the first two break it (last night the opposite was the case, I don't know what changed).
With the debugging println("Map") it prints ¥ (with no new line). I'm writing at 9600 and the serial monitor is at 9600 as well.
The final two println don't show up on the serial monitor.
However, the function apparently completes because I can call other functions otherwise and they work.
In addition, I'm using serial commands.
  if (stringComplete){
    if (serialRead=="map") {
      Serial.println("Map");
      mapping();
      serialRead="";
In that case, the debugging line yields different values each time I call map: MØ, ­-Ø, Ma, M°, again with no new line. Putting the debugging line after mapping() yields no output in the serial monitor. Removing mapping(), I get Map, as expected.
If anyone can help at all, it'd be much appreciated. I can't make any sense out of this whatsoever.
void mapping(){ //connect to B and W; this function determines the digipot settings for 1-6 lighted circuits; it should be I*(number of circuits)
  for (int i=0;i<6;i++){
    float currentMap50[256] = { //this holds the currents measured at every setting of digipot50
    SPIfunction(pow(2,(i+1))-1,cellSwitchPin); //this sets the number of open dot loops
    for(int k=0;k<256;k++){ //this loop goes through all the digipot50 settings to fill out currentMap50
      SPIfunction(k,digipot50Pin);
      currentMap50[k]=currentSense();
      if (k>=1) /*idea here is to keep the currentMap monotonically increasing to allow searches to be done and the function is actually monotonical
       increasing except for errors*/
        if (currentMap50[k] <= currentMap50[k-1])
          currentMap50[k]=1.001*currentMap50[k-1];  //this is one of the lines causing problems
    int m = 0; //this determines which position in currentMap50 is closest to the target current
    while((currentMap50[m]-(i+1)*I) < 0) //while the error is decreasing; this condition is the other line causing problems
    m++;
    if (m > 255) //subtracting 26 (5 kOhm) so that digipot10 finds the precise value
      digipot50Set[i]=229;
    else if (m<26)
      digipot50Set[i]=0;
      digipot50Set[i]=m-26;
    SPIfunction(digipot50Set[i],digipot50Pin);
    //then repeat the above
    float currentMap10[256] = {
    for(int n=0;n<256;n++){
      SPIfunction(n,digipot10Pin);
      currentMap10[n]=currentSense();
      if ((currentMap10[n] <= currentMap10[n-1]) && (n >= 1))
        currentMap10[n]=1.001*currentMap10[n-1];
    int p = 0;
    while((currentMap10[p]-(i+1)*I)<0){ //while the error is decreasing
      p++;
    if (p > 255)
      digipot10Set[i]=255;
      digipot10Set[i]=p;
  for(int i=0;i<6;i++)
    Serial.println(digipot50Set[i]);
    Serial.println(digipot10Set[i]);
This array is 1024 bytes long. If you are using a 328 based Arduino (Duemilanove, Nano etc.) you only have 2048 bytes of SRAM for your whole program and you gobble up half of it in that for loop.
That is probably what is causing the problem but without seeing the rest of your code there's no way to know.
Pete
Ohhh. I have two such arrays in that function, so that'd do it.
I guess my option would be to use a short integer array and multiply all my values by 100 or 1000 and then truncate them.
As long as someone's reading this, how do I delete an array?
Fixed. Thanks.
in a source file, hit the backspace.
or, leave the scope it was declared in.
or if the array is dynamic, use 'delete [] xxx'. ( float currentMap50[256] is not dynamic )
if you only need one at a time. add extra scope
void Func( void )
      float a[256];
      //Work on a
     //Array a no longer valid
      float b[256]
      //Work on b
    //Array b no longer valid
or share the var name, use smaller data types, use less entries.
Ah... I hadn't considered that it might be possible to add scope like that. I was a little tunnel-visioned that that could only be done with if statements and such. The things you learn.
Thanks for that.
