I'm able to get my code to work. What I want to do is flush the input buffer after each data entry to get hold the serial input until another value is entered. I"m able to do this.
However, when I try to reduce the 3 lines of code for this into 1 line of code (which I made as a function), it skips every other entry.
Here's what works:
while (Serial.available() > 0)
{ Serial.read(); // flush input buffer
Here's what I want to do:
void flush_input(void)
// flush input buffer, do before asking for new input. Notes: https://forum.arduino.cc/t/serial-input-basics-updated/382007
When I try to replace the 3 lines of code with the function call void flush_input(void) is when the serial monitor skips my entry, e.g. race 2 will be entered as 0.00. So will race 4
Full code:
Input runner's time for each race.
Runner ran 4 times per week, and recorded these times.
Runner1
Runner2
Structure:
- Use 1 array to store both runners' data. Thus, 2 rows, 4 columns, so array[2][4]
Sort:
- run times per runner, low to high.
Display:
- slowest run times for each runner
- fastest run time for each runner
Advanced:
- edit lowest run times, likely uses pointers or references
#include<Arduino.h>
//global vars
int runner_num = 1; // defines start num of which runner is running
// Function Prototypes
void which_runner(int runner_num);
//void flush_input(void);
// arrays holding runners times
const int total_runners = 2;
const int num_of_races = 4;
double run_time[total_runners][num_of_races]; // defines a 2x4 matrix. Row 1 = runner 1 data, Row 2 = runner 2 data
//Enter run times for runners
which_runner(runner_num);
// 1st runner data, enter all
for(int j=0; j < num_of_races; j++)
//Serial.println("Runner 1***"); //debug line
Serial.print("race ");
Serial.print(j+1); //race number
Serial.print(": ");
while (Serial.available() == 0) {} // waits until data is entered into serial monitor
run_time[runner_num][0] = Serial.parseFloat(); //takes incoming characters and converts it to a number. This is read into the buffer altogether. Default is data type long.
Serial.print(run_time[runner_num][0]);
Serial.println(" minutes");
// void flush_input(void);
// increase runner number for display and entry of new array for run times
runner_num++;
// 2nd runner data, enter all
for(int i=0; i<num_of_races; i++)
//Serial.println("Runner 2***"); // debug line
Serial.print(i+1); //race number
Serial.print(": ");
runner_num++;
if(runner_num > total_runners)
Serial.print("\nAll race data has been entered.");
Serial.flush();
exit(0);
// Function Definitions
Serial.print("***\nEnter times for runner: ");
Serial.println(runner_num);
return 0;
//return 0;
