Function for incrementing variable every 1000 ms
Is making this Function for incrementing variable every 1000 ms good for measuring realtime power consumption in Wh . If it is what is the best way to vrite that kind of function. Thanks
Don't use a function. Just put a section of loop that fires every 1000 ms. Check out Blink without delay and just increment your variable instead of blinking.
Not sure if i know how to do it I am just beginner :S
steskaniarduino: Not sure if i know how to do it I am just beginner :S
Did you try?
The IDE includes the blink without delay example. Load it and read it.
This is code for measuring power consumption and current
#include <LiquidCrystal.h>
const int sensorIn = A0;
int mVperAmp = 66;
double Voltage = 0;
double Power = 0;
double VRMS = 0;
int time = 0;
double AmpsRMS = 0;
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
/*time counter*/
unsigned long previousMillis = 0;
const long interval = 1000;
void setup(){
lcd.begin(16,2);
Voltage = getVPP();
VRMS = (Voltage/2.0) *0.707;
AmpsRMS = (VRMS * 1000)/mVperAmp;
lcd.setCursor(0,0);
lcd.print("I=");
lcd.print(AmpsRMS);
lcd.print(" A");
Power = 220*AmpsRMS;
  lcd.setCursor(7,0);
  lcd.print("P=");
  lcd.print(Power,2);
  lcd.print(" W");
if(currentMillis - previousMillis >=interval){
	time++;
lcd.setCursor(0,1);
lcd.print(whC(int time, float Power ),2)
float getVPP()
float result;
int readValue; //value read from the sensor
int maxValue = 0; // store max value here
int minValue = 1023; // store min value here
uint32_t start_time = millis();
while((millis()-start_time) < 1000) //sample for 1 Sec
readValue = analogRead(sensorIn);
// see if you have a new maxValue
if (readValue > maxValue)
/*record the maximum sensor value*/
maxValue = readValue;
if (readValue < minValue)
minValue = readValue;
// Subtract min from max
result = ((maxValue - minValue) * 5.0)/1023.0;
return result;
float whC(int time, float Power ){
	float result;
	result = (Power * time)/3600;
	return result;
Looks pretty good, you need to reset previousmillis inside the time check loop so it happens again 1 second later
