Function for setting the time
I am attempting to use a keypad (finally got it working) to set the time. The time and keypad libraries are invoked at the top. digit1 and digit2 are both static ints. The keypad takes in a variable assigned to it (0-9) and should then enter the switch statement where it takes key (a char data type) and give the function a number (the variable is 'conversion and is an int).
This is in the void loop.
  Serial.print("What hour is it?");
  digit1 =HOUR1digit();
  digit2 =HOUR2digit(); // Set the new hour
  NEWHOUR = setHOUR();
  delay(200);
These are three functions for setting the hour (outside of void loop). The first two store a digit, and then the final function combines them. I got the idea from a different thread in this forum.
int HOUR1digit(){ // USED FOR SETTING HOUR
key = KEYPAD.waitForKey();
delay(200);
switch (key){
case '1':{conversion=1;}
case '2':{conversion=2;}
case '3':{conversion=3;}
case '4':{conversion=4;}
case '5':{conversion=5;}
case '6':{conversion=6;}
case '7':{conversion=7;}
case '8':{conversion=8;}
case '9':{conversion=9;}
case '0':{conversion=0;}}
     digit1=conversion;
     Serial.println(key);
     Serial.println(digit1);
    return digit1;
int HOUR2digit(){ // USED FOR SETTING HOUR
    key =KEYPAD.waitForKey();
switch (key){
        digit2=conversion;
        Serial.println(digit2);
        return digit2;}}
int setHOUR(){ // USED FOR SETTING HOUR
int newHOUR;
if (digit1>2)
   {newHOUR=digit1;
   return newHOUR;}
newHOUR = (10*digit1)+digit2;
if (newHOUR>24){
    newHOUR=24;
    return newHOUR;}
return newHOUR;}
I am printing to the serial monitor to figure out what is happening. It prints the correct key which I select, but in the switch statement, the output of 'conversion' is zero. Any thoughts?
You might want to put some break statements in there to stop the case from falling thru.
Thanks.
You could also replace the whole switch by a single line, as simple as:
digit1 = key - '0';
