hello everybody
I am trying to generate waves using arduino UNO and AD9833 module, I have searched for helping codes and Fortunately I have found the following code from this website: AD9833 Micro Waveform Generator
//* ARDUINO TESTCODE FOR AD9833 Micro Waveform Generator
//* https://www.changpuak.ch/electronics/AD9833-MicroWaveformGenerator.php
//* Software Version 1.0,
//* 25.04.2016, Alexander C. Frank
#include "Wire.h"
#define MAX5381 0x64
// Suffix "L" : 0x60
// Suffix "M" : 0x62
// Suffix "N" : 0x64
// Suffix "P" : 0x66
#include "TimerOne.h"
int TimerUpdateRate = 1000;
const int SOURCE = A5; // ARBITRARY = 1 OR AD9833 = 0
const int FSYNC = 6;
const int SDATA = 7;
const int SCLK = 8;
const float CRYSTAL = 24000000.0 ;
const int SINE = 0x2000;
const int SQUARE = 0x2020;
const int TRIANGLE = 0x2002;
unsigned long FREQ = 1000;
char Command ;
byte byteRead ;
//! Updates the DDS registers
void UpdateDDS(unsigned int data){
unsigned int pointer = 0x8000;
// Serial.print(data,HEX);Serial.print(" ");
digitalWrite(FSYNC, LOW); // AND NOW : WAIT 5 ns
for (int i=0; i<16; i++){
if ((data & pointer) > 0) { digitalWrite(SDATA, HIGH); }
else { digitalWrite(SDATA, LOW); }
digitalWrite(SCLK, LOW);
digitalWrite(SCLK, HIGH);
pointer = pointer >> 1 ;
digitalWrite(FSYNC, HIGH);
//! Updates the Freq registers
void UpdateFreq(long FREQ, int WAVE){
long FTW = (FREQ * pow(2, 28)) / CRYSTAL;
if (WAVE == SQUARE) FTW = FTW << 1;
unsigned int MSB = (int)((FTW & 0xFFFC000) >> 14);
unsigned int LSB = (int)(FTW & 0x3FFF);
LSB |= 0x4000;
MSB |= 0x4000;
UpdateDDS(0x2100);
UpdateDDS(LSB);
UpdateDDS(MSB);
UpdateDDS(0xC000);
UpdateDDS(WAVE);
//! Reads User Input from Serial
void ReadUserInput()
boolean ende = false ;
FREQ = 0;
while ( ( Serial.available() ) || ( ende == false ) )
byteRead = Serial.read();
if ( byteRead == 10 ){ ende = true ; }
if (( byteRead > 64 ) & (byteRead < 91)) {
Command = byteRead ; } // A..Z
if (( byteRead > 47 ) & (byteRead < 58)) {
FREQ = FREQ * 10;
FREQ = FREQ + byteRead - 48 ; } // 0..9
pinMode(SOURCE, OUTPUT);
pinMode(FSYNC, OUTPUT);
pinMode(SDATA, OUTPUT);
pinMode(SCLK, OUTPUT);
digitalWrite(SOURCE, LOW);
Wire.begin();
// Micro Hack fails ....
// while (!Serial) { delay(10); // wait for serial port to connect. }
delay(6999);
Serial.println("AD9833 Micro Waveform Generator V1.0");
Serial.println("-------------------------------------------------------");
Serial.println("COMMAND : [WAVEFORM]+[FREQUENCY IN HERTZ]");
Serial.println("WAVEFORM : S-SINE, T-TRIANGLE, R-RECTANGLE, A-ARBITRARY");
Serial.println("E.G:: S1000 OUTPUTS A SINE AT 1000 Hz");
// INIT DDS, AS DESCRIBED IN AN-1070, "Programming the AD9833/AD9834"
// BY LIAM RIORDAN (ANALOG DEVICES)
UpdateDDS(0x2100);
UpdateDDS(0x50C7);
UpdateDDS(0x4000);
UpdateDDS(0xC000);
UpdateDDS(0x2000);
// SWITCH TO SOURCE = DDS
// NOW THERE SHOULD BE A
// 384 Hz SIGNAL AT THE OUTPUT
delay(999);
ReadUserInput();
switch (Command)
case 82 :
// THAT WAS AN "R" FOR "DAC data MSB"
Serial.print("\nRECTANGLE, FREQ = ");
Serial.print(FREQ,DEC);Serial.println(" Hz");
UpdateFreq(FREQ, SQUARE);
Serial.println("\nO.K.");
case 83 :
// THAT WAS AN "S" FOR "Sinusoid"
Serial.print("\nSINE, FREQ = ");
UpdateFreq(FREQ, SINE);
case 84 :
// THAT WAS AN "T" FOR "Triangle"
Serial.print("\nTRIANGLE, FREQ = ");
UpdateFreq(FREQ, TRIANGLE);
default:
Serial.println("\nUnknown Command.");
Serial.println("Try again :-)");
delay(100);
// END OF FILE.
but unfortunately it didn't work properly, and i get this error:
Arduino: 1.8.5 (Windows 7), Board: "Arduino/Genuino Uno"
Sketch uses 5256 bytes (16%) of program storage space. Maximum is 32256 bytes.
Global variables use 660 bytes (32%) of dynamic memory, leaving 1388 bytes for local variables. Maximum is 2048 bytes.
avrdude: ser_open(): can't set com-state for "\.\COM3"
An error occurred while uploading the sketch
option enabled in File -> Preferences.
. so can anyone help please?
