function issues
Hi, I've been trying to build a small robot. I have gotten all the hardware strait with a motor driver and all but I'm having problems getting my left turn function to run. I keep getting the error: variable or field 'left' declared void
heres my code:
int fore = 12; //directional pins on the motor driver
int rev = 11; //used to spin the motor counter foreward and reverse
int angle = 2; //the interupter contact when high is the limit of turning
  pinMode(fore, OUTPUT);
  pinMode(rev, OUTPUT);
  pinMode(angle, INPUT);
  int limit = digitalRead(angle);
  left(limit, angle, fore);
// my left turn function
void left(limit, angle,fore){
  while (limit != HIGH){
    digitalWrite(fore, HIGH);
  digitalWrite(fore, LOW);
}/code]
No types
You have to write the type of the argument, as such:
void left( int limit, int angle, int fore )
But, as you already declared those variable angle and fore, you can simply do this:
void left( int limit )
The error message is confusing. I've made the same mistake more than once.
Parameters in a function definition must have type declarations. Perhaps:
void left(byte limit, byte angle, byte fore)
thanks alot
